メインコンテンツにスキップ
How to Rewire a Lamp
必要な工具と部品
  1. How to Rewire a Lamp, Cord: 手順 1、 3の画像 1 How to Rewire a Lamp, Cord: 手順 1、 3の画像 2 How to Rewire a Lamp, Cord: 手順 1、 3の画像 3
    • Before starting the process, remove the lamp shade and bulb by hand.
    • Make sure the lamp is unplugged to avoid the risk of electrocution.
  2. How to Rewire a Lamp: 手順 2、 3の画像 1 How to Rewire a Lamp: 手順 2、 3の画像 2 How to Rewire a Lamp: 手順 2、 3の画像 3
    • Loosen the setscrew with the screwdriver so you can unscrew the socket base.
    • Unscrew the socket base from the threaded tube with your hand.
  3. How to Rewire a Lamp: 手順 3、 3の画像 1 How to Rewire a Lamp: 手順 3、 3の画像 2 How to Rewire a Lamp: 手順 3、 3の画像 3
    • With your hand, pry the socket shell out of its base.
    • Remove the socket with your hand and then cut the wires with the wire cutters.
    • The neutral wire connects to the wide plug blade and is distinguished from the hot wire by ribs, color, printing, or indentations in the plastic insulation.
  4. How to Rewire a Lamp: 手順 4、 2の画像 1 How to Rewire a Lamp: 手順 4、 2の画像 2
    • Strip off 1/2" of the insulation with the wire stripper and twist the wire strands together by hand.
    • If you pull off any wire strands while stripping, cut back the cord with the Diagonal cutter.
  5. How to Rewire a Lamp: 手順 5、 3の画像 1 How to Rewire a Lamp: 手順 5、 3の画像 2 How to Rewire a Lamp: 手順 5、 3の画像 3
    • By hand, tie an underwriters knot in the cord.
    • Also by hand, connect the wires by wrapping them clockwise around the screws and tighten and connect the neutral wire to the silver screw.
    • An underwriter's knot prevents the wires from pulling out of the screw terminals when cord is tugged. ( The entire process of tying an underwriter knot can be done by hand . Form a loop using the first wire. Then, form a loop around the first wire and pass the tail through its loop. The strain on the cable is now taken by the knot.)
  6. How to Rewire a Lamp: 手順 6、 3の画像 1 How to Rewire a Lamp: 手順 6、 3の画像 2 How to Rewire a Lamp: 手順 6、 3の画像 3
    • By hand, pull the excess cord down through the lamp.
    • Still using your hand, slip the insulation sleeve and socket shell over the socket and snap the shell into the base.
ゴール
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Molly
メンバー登録日: 10/20/17
119 ポイント
1ガイドが承認済み
チーム
Missouri Western, Team S1-G4, Adkins Fall 2017 Missouri Western, Team S1-G4, Adkins Fall 2017人のメンバー
MWSU-ADKINS-F17S1G4
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 39
今までの合計 1,285
