はじめに
If the shaver is left dead and uncharged for too long, the battery depletes to a level that is unrecognisable by the charger. Many may think the device is past its prime, since the battery does not charge, but it is not the case.
A quick fix to get the device back online is to provide 3.7 - 4.2 V to the battery, enabling the circuitry to power up, and be recognised by the charger.
Disconnect the motor, and remove the motherboard and battery assembly from the housing.
Provide 3.7-4.2 V to the battery using a voltage-controlled power supply or buck converter. (A charging circuit might work, but since the battery voltage is so low, it might be undetectable)
Depending on how depleted the battery is, the period of 'charge' will vary. Monitoring the rate of voltage discharge provides an indication of the "holding capacity" of the battery.
Quickly assemble the shaver when the battery holds a voltage for a few minutes.
Place the shaver on the charging dock or cleaning station to begin the charging process.
Once charged, the shaver worked as expected.
Naturally after many years of use, the battery shows sign of reduced capacity.
ある他の人がこのガイドを完成しました。
コメント 1 件
I rather send it in to be reset. Mine is new never used just sat until i finally started ahaving again like 4 or 5 yrs.
