はじめに
Fridge door opening the wrong way and bumping into cabinets? Don’t panic. Most refrigerator doors come with a reversible door design—so you can change the door direction yourself without a technician. Reversing the fridge door swing lets you better position the appliance in a tight kitchen without banging into adjacent cabinets. This guide shows you how to move the hinges and decorative plugs to the opposite side, align the door, and restore a proper seal.
⚠️ Always unplug the appliance before starting.
必要な工具と部品
手順1 Disconnect power and inspect hinge layout to prepare for reversing the fridge door
Note which side holds the hinges and which side carries decorative hole plugs.
手順2 Remove decorative plastic covers
Take out all plastic caps and trims from both sides to avoid breaking them during the swap.
手順3 Unscrew upper hinge and lift off door
Remove the screws securing the top hinge bracket with the appropriate screwdriver.
Lift the door straight up and set it aside once the hinge is free.
手順4 Detach remaining hinge brackets
Unscrew the middle and bottom hinge brackets from the cabinet so they are completely free.
手順5 Transfer hinges and plugs to opposite side
Use a Torx screwdriver to loosen hinge pins if needed and rotate them toward the new hinge side.
Press decorative plugs into the now‑unused holes to keep the cabinet sealed and tidy.
手順6 Install hinges on new side
Fit the former bottom hinge to the top position on the opposite side and install its screws.
Fit the former top hinge to the bottom position on the opposite side to match the new swing direction.
手順7 Rehang the door
Ensure decorative caps on the door are also swapped so no holes remain exposed.
Rehang the door by screwing back the initial screws.
手順8 Check seal and alignment
Close the door and listen for the gasket to make a continuous sealing sound along the frame.
手順9 Refit remaining trims
Snap all remaining decorative plastics back into place to finish the appearance.
Reconnect the refrigerator to power and monitor that it cools normally. If you do not hear the gasket gripping sound or notice uneven gaps, loosen the hinge screws slightly, realign the door, and retighten until the seal is uniform.
That’s it! You’ve successfully changed your refrigerator door’s direction. Most modern fridges are designed with this kind of reversible door swing in mind—so next time your kitchen layout changes, you’re all set.
ある他の人がこのガイドを完成しました。
