メインコンテンツにスキップ
How to Resurface a Fishing Lure
必要な工具と部品
  1. How to Resurface a Fishing Lure, How to Resurface a Fishing Lure: 手順 1、 1の画像 1
    • Evaluate the material your lures are made from. This will affect your process slightly.
  2. How to Resurface a Fishing Lure: 手順 2、 2の画像 1 How to Resurface a Fishing Lure: 手順 2、 2の画像 2
    • Remove the treble hooks and keyrings from the lure body.
    • The hooks are very sharp!
  3. How to Resurface a Fishing Lure: 手順 3、 2の画像 1 How to Resurface a Fishing Lure: 手順 3、 2の画像 2
    • Sand your lures. They can either be fully sanded or just scuffed on the surface. This helps the polyurethane bond to the surface.
    • Lures can be repainted with acrylic paints but that is out of the scope of this tutorial.
  4. How to Resurface a Fishing Lure: 手順 4、 2の画像 1 How to Resurface a Fishing Lure: 手順 4、 2の画像 2
    • Wipe the freshly sanded lures with a wet cloth. Allow it to fully dry.
  5. How to Resurface a Fishing Lure: 手順 5、 2の画像 1 How to Resurface a Fishing Lure: 手順 5、 2の画像 2
    • Tie a string to the lures and dip the lures fully into the polyurethane.
    • Do this step in a large and well ventilated space. Fumes from your polyurethane should not be inhaled.
  6. How to Resurface a Fishing Lure: 手順 6、 1の画像 1
    • Hang your lures up to dry for at least 24 hours.
終わりに
All that is necessary after the lure's new surface has cured is to reattach the keyring and treble hooks.
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Zach Solka
メンバー登録日: 03/30/16
149 ポイント
1ガイドが承認済み
チーム
Michigan Tech, Team 1-24, Lauer Spring 2016 Michigan Tech, Team 1-24, Lauer Spring 2016人のメンバー
MTU-LAUER-S16S1G24
1 メンバー
2のガイドは作成済み
2 件のコメント
Looking for your first rod so you can take part in the great sport of fishing? Have you looked through some catalogs or browsed in sporting goods store and are already confused? All these new words to learn. Spinning fishing rods? Bait-casting '''fishing rods'''? Spin casting fishing rods? What do all these things mean?
mahbub_rahman - 返信
Very interesting post. Every step explains with the images are really helpful for the beginners. I love fishing in Puerto Vallarta and your post helps me a lot to resurface my fishing lure. Thanks a million and please keep up the effective work.
Marlas PV Landing - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 25
今までの合計 802
