メインコンテンツにスキップ
How to Restring a French Horn
必要な工具と部品
  1. How to Restring a French Horn, How to Restring a French Horn: 手順 1、 3の画像 1 How to Restring a French Horn, How to Restring a French Horn: 手順 1、 3の画像 2 How to Restring a French Horn, How to Restring a French Horn: 手順 1、 3の画像 3
    • Place your horn where the back is easily accessible.
    • Loosen the set of screws, but DON’T take them out! Just loosen them enough that the string can wrap around.
  2. How to Restring a French Horn: 手順 2、 3の画像 1 How to Restring a French Horn: 手順 2、 3の画像 2 How to Restring a French Horn: 手順 2、 3の画像 3
    • Cut about 7-8 inches of string only if you are going to use a brand new roll of string, and tie a small knot on one end of the string.
    • If it is the exact string, make sure there is a knot at the one end of the string.
    • With the knot, the string should be about 51/2-6 inches.
  3. How to Restring a French Horn: 手順 3、 2の画像 1 How to Restring a French Horn: 手順 3、 2の画像 2
    • Put the string in the top hole of the valve and pull.
    • You are going to pull it toward the bottom and wrap it at the bottom of the rotor post.
  4. How to Restring a French Horn: 手順 4、 3の画像 1 How to Restring a French Horn: 手順 4、 3の画像 2 How to Restring a French Horn: 手順 4、 3の画像 3
    • Wrap the string around the screw and tighten the screw.
  5. How to Restring a French Horn: 手順 5、 3の画像 1 How to Restring a French Horn: 手順 5、 3の画像 2 How to Restring a French Horn: 手順 5、 3の画像 3
    • Pull the string to wrap the top of the rotor.
    • Put the string into the hole at the bottom of the valve.
  6. How to Restring a French Horn: 手順 6、 3の画像 1 How to Restring a French Horn: 手順 6、 3の画像 2 How to Restring a French Horn: 手順 6、 3の画像 3
    • Wrap the string around the screw.
    • Tighten the screw.
  7. How to Restring a French Horn: 手順 7、 3の画像 1 How to Restring a French Horn: 手順 7、 3の画像 2 How to Restring a French Horn: 手順 7、 3の画像 3
    • Make sure your valve buttons are leveled, if it is too tight or to loose where it is not leveled, then you will have to repeat steps 1-6.
    • If your horn looks like any of these photos then congrats!! You are finished.
    • You may now move on with your day and go practice! Make sure to press the valve a coupe of times to make sure everything is secure well.
終わりに
作成者
1人の作成者と共同作成されました。
Claudia aguilar
メンバー登録日: 04/16/24
145 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 21-21, Briggs Spring 2024 CSU Los Angeles, Team 21-21, Briggs Spring 2024人のメンバー
CSULA-BRIGGS-S24S21G21
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 44
今までの合計 463
