メインコンテンツにスキップ
How to Restring a Floyd Rose Bridge Guitar
必要な工具と部品
  1. How to Restring a Floyd Rose Bridge Guitar, How to Restring a Floyd Rose Bridge Guitar: 手順 1、 1の画像 1
    • Unlock the double locking screws under the headstock using the hex key.
  2. How to Restring a Floyd Rose Bridge Guitar: 手順 2、 2の画像 1 How to Restring a Floyd Rose Bridge Guitar: 手順 2、 2の画像 2
    • Tip the Floyd Rose Bridge forward by pushing down on the tremolo (whammy bar).
  3. How to Restring a Floyd Rose Bridge Guitar: 手順 3、 2の画像 1 How to Restring a Floyd Rose Bridge Guitar: 手順 3、 2の画像 2
    • Place a 9V battery (or similarly shaped object) in to the cut-out space under the bridge to hold the bridge steady.
    • When the 9V battery is in its place, you can now let go of the tremolo (whammy bar) and the bridge will stay steady for the process.
  4. How to Restring a Floyd Rose Bridge Guitar: 手順 4、 1の画像 1
    • Unwind the old strings using the string winder.
  5. How to Restring a Floyd Rose Bridge Guitar: 手順 5、 2の画像 1 How to Restring a Floyd Rose Bridge Guitar: 手順 5、 2の画像 2
    • Loosen up the pegs that are below the fine tuners using the hex key, rotating counter-clockwise.
    • Gently pull the strings out of the block openings.
  6. How to Restring a Floyd Rose Bridge Guitar: 手順 6、 2の画像 1 How to Restring a Floyd Rose Bridge Guitar: 手順 6、 2の画像 2
    • Insert the strings one by one in to their respected block openings on the bridge.
  7. How to Restring a Floyd Rose Bridge Guitar: 手順 7、 1の画像 1
    • Tighten up the pegs below the fine tuners using the hex key, rotating clockwise this time.
  8. How to Restring a Floyd Rose Bridge Guitar: 手順 8、 2の画像 1 How to Restring a Floyd Rose Bridge Guitar: 手順 8、 2の画像 2
    • Feed each string in through the tuners on the headstock.
  9. How to Restring a Floyd Rose Bridge Guitar: 手順 9、 3の画像 1 How to Restring a Floyd Rose Bridge Guitar: 手順 9、 3の画像 2 How to Restring a Floyd Rose Bridge Guitar: 手順 9、 3の画像 3
    • Tune each string one at a time.
    • Cut the extra end of the strings after tuning using the wire cutter.
    • Finally, lock the double locking screws back using the hex key.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Hasan28
メンバー登録日: 01/17/21
199 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G5, O'Regan Winter 2021 York University, Team S1-G5, O'Regan Winter 2021人のメンバー
YORK-O'REGAN-W21S1G5
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 25
今までの合計 742
