メインコンテンツにスキップ
How to Restore the Color of Canvas Shoes
必要な工具と部品
  1. How to Restore the Color of Canvas Shoes, How to Restore the Color of Canvas Shoes: 手順 1、 3の画像 1 How to Restore the Color of Canvas Shoes, How to Restore the Color of Canvas Shoes: 手順 1、 3の画像 2 How to Restore the Color of Canvas Shoes, How to Restore the Color of Canvas Shoes: 手順 1、 3の画像 3
    • Remove the shoelaces from the shoes if you don't want to dye them.
  2. How to Restore the Color of Canvas Shoes: 手順 2、 3の画像 1 How to Restore the Color of Canvas Shoes: 手順 2、 3の画像 2 How to Restore the Color of Canvas Shoes: 手順 2、 3の画像 3
    • Soak your shoes in a tub of cool water.
    • This will maximize the absorption of the dye.
  3. How to Restore the Color of Canvas Shoes: 手順 3、 1の画像 1
    • Heat a pot of water just below boiling point.
    • Pour the water in a container large enough to hold your shoes.
  4. How to Restore the Color of Canvas Shoes: 手順 4、 3の画像 1 How to Restore the Color of Canvas Shoes: 手順 4、 3の画像 2 How to Restore the Color of Canvas Shoes: 手順 4、 3の画像 3
    • Add the tie-dye to the heated water.
    • Stir the tie-dye mix until it dissolves.
  5. How to Restore the Color of Canvas Shoes: 手順 5、 2の画像 1 How to Restore the Color of Canvas Shoes: 手順 5、 2の画像 2
    • Completely submerge your shoes with the soles facing upwards into the container with the dye.
    • Leave them to soak for 10 minutes to 1 hour.
  6. How to Restore the Color of Canvas Shoes: 手順 6、 3の画像 1 How to Restore the Color of Canvas Shoes: 手順 6、 3の画像 2 How to Restore the Color of Canvas Shoes: 手順 6、 3の画像 3
    • Remove your shoes and wash them with cool water and a mild detergent to remove the excess ink.
終わりに
Make sure your footwear was properly washed and remove any excess dye, then simply let them dry before using them.
作成者
5人の作成者と共同で作成されました。
Gabriel E. Fuentes-Rosado
メンバー登録日: 10/06/21
141 ポイント
1ガイドが承認済み
チーム
コメント 1 件
I needed to thank you for this extraordinary data and information, I most certainly cherished every single piece of it. Kindly compose an article about Cartridge heater supplier this will be help full.
Leo Daniels - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 26
過去 30 日: 166
今までの合計 7,349
