メインコンテンツにスキップ
How to Restore and Season a Cast Iron Pan
必要な工具と部品
  1. How to Restore and Season a Cast Iron Pan, How to Restore and Season a Cast Iron Pan: 手順 1、 1の画像 1
    • Soak your pan in a roughly 50/50 mix of distilled white vinegar and water for about an hour.
    • You can wait longer if the rust is particularly bad.
  2. How to Restore and Season a Cast Iron Pan: 手順 2、 1の画像 1
    • Remove the pan from the vinegar solution.
    • Immediately apply baking soda to the pan to neutralize the acidity of the vinegar.
    • Start to wipe away the rust with steel wool.
  3. How to Restore and Season a Cast Iron Pan: 手順 3、 1の画像 1
    • Scour your pan inside and out with steel wool until either the rust or the white heat-damaged area appears black.
  4. How to Restore and Season a Cast Iron Pan: 手順 4、 2の画像 1 How to Restore and Season a Cast Iron Pan: 手順 4、 2の画像 2
    • Thoroughly dry your pan and place it over medium flame or in a 350 degrees Fahrenheit oven for 5 to ten minutes to allow it to completely dry.
  5. How to Restore and Season a Cast Iron Pan: 手順 5、 3の画像 1 How to Restore and Season a Cast Iron Pan: 手順 5、 3の画像 2 How to Restore and Season a Cast Iron Pan: 手順 5、 3の画像 3
    • Apply a generous amount of oil to the pan and rub it all over with a paper towel, making sure to hit every nook and cranny.
    • This process will remove the thin film of rust left by step 4.
  6. How to Restore and Season a Cast Iron Pan: 手順 6、 1の画像 1
    • Use a clean paper towel to thoroughly wipe off the pan.
  7. How to Restore and Season a Cast Iron Pan: 手順 7、 2の画像 1 How to Restore and Season a Cast Iron Pan: 手順 7、 2の画像 2
    • Repeat steps 5 and 6.
    • Place the pan upside down in an oven and turn it up to 500 degrees Fahrenheit or as high as it will go.
    • Once the oven reaches that temperature leave the pan in it for one hour.
  8. How to Restore and Season a Cast Iron Pan: 手順 8、 1の画像 1
    • Turn off the heat.
    • Allow the pan to cool naturally in the oven.
  9. How to Restore and Season a Cast Iron Pan: 手順 9、 1の画像 1
    • Your pan is now seasoned.
    • You may repeat steps 5-8 up to 6 times for higher quality results.
終わりに
You’re all done!
作成者
1人の作成者と共同作成されました。
Mikhail Keyes
メンバー登録日: 06/14/21
219 ポイント
1ガイドが承認済み
チーム
Idaho State University, Team S1-G6, Watkins Summer 2021 Idaho State University, Team S1-G6, Watkins Summer 2021人のメンバー
ISU-WATKINS-SU21S1G6
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 59
今までの合計 1,243
