メインコンテンツにスキップ
How to Restore a Used Canvas
必要な工具と部品
  1. How to Restore a Used Canvas, How to Restore a Used Canvas: 手順 1、 2の画像 1 How to Restore a Used Canvas, How to Restore a Used Canvas: 手順 1、 2の画像 2
    • Insert a spudger beneath a staple and pry upwards to remove it.
    • Repeat for the remaining staples.
    • Caution: Be careful when handling sharp staples.
  2. How to Restore a Used Canvas: 手順 2、 2の画像 1 How to Restore a Used Canvas: 手順 2、 2の画像 2
    • Remove the canvas and place the wood frame aside
    • Lay out the used canvas flat on a clean surface.
    • Wipe the canvas down with a damp cloth.
  3. How to Restore a Used Canvas: 手順 3、 1の画像 1
    • Gently use fine grit sandpaper to remove any old clumps of paint on the canvas.
  4. How to Restore a Used Canvas: 手順 4、 3の画像 1 How to Restore a Used Canvas: 手順 4、 3の画像 2 How to Restore a Used Canvas: 手順 4、 3の画像 3
    • Add an even layer of white acrylic paint on the entire canvas.
    • Use a paintbrush to evenly spread the paint on the canvas.
  5. How to Restore a Used Canvas: 手順 5、 1の画像 1
    • To make the drying process faster, use a portable fan or hairdryer.
    • Continue to paint even layers until the canvas is covered evenly.
  6. How to Restore a Used Canvas: 手順 6、 1の画像 1
    • After the paint is completely dry, lightly sand down any noticeable bumps to get a smooth finish on the canvas.
  7. How to Restore a Used Canvas: 手順 7、 3の画像 1 How to Restore a Used Canvas: 手順 7、 3の画像 2 How to Restore a Used Canvas: 手順 7、 3の画像 3
    • Grab the wood frame and fold one side of the canvas to its original state.
    • Tightly secure the canvas and firmly set the stapler on the area that needs a staple.
    • With a steady and secure fist, firmly press on the top of the stapler.
    • Continue this process all around the canvas.
  8. How to Restore a Used Canvas: 手順 8、 3の画像 1 How to Restore a Used Canvas: 手順 8、 3の画像 2 How to Restore a Used Canvas: 手順 8、 3の画像 3
    • Tightly fold the corners of the canvas and secure it with a final staple keeping it in place.
ゴール
作成者
1人の作成者と共同作成されました。
Sandra Henriquez
メンバー登録日: 04/21/21
157 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team S1-G7, Harris Spring 2021 CSU Los Angeles, Team S1-G7, Harris Spring 2021人のメンバー
CSULA-HARRIS-S21S1G7
2 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 39
今までの合計 608
