メインコンテンツにスキップ
How to Restore Wool’s Water Resistance
必要な工具と部品
  1. How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: 手順 1、 3の画像 1 How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: 手順 1、 3の画像 2 How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: 手順 1、 3の画像 3
    • Fill a bowl with water at room temperature (20 °C or 68 °F).
    • Use 2 L of water per 200 g of wool.
  2. How to Restore Wool’s Water Resistance: 手順 2、 1の画像 1
    • Add 1/2 teaspoon of wool wash per 2 L of water.
  3. How to Restore Wool’s Water Resistance: 手順 3、 2の画像 1 How to Restore Wool’s Water Resistance: 手順 3、 2の画像 2
    • Insert the articles into the bowl and let soak for 30 minutes.
    • Carefully squeeze the items to allow absorption of soap and water through the wool fibres.
  4. How to Restore Wool’s Water Resistance: 手順 4、 1の画像 1
    • Lift the items out of the water and gently squeeze to remove excess water and soap.
  5. How to Restore Wool’s Water Resistance: 手順 5、 1の画像 1
    • Refill the bowl with room temperature water.
    • Use the same volume of water as in Step 1.
  6. How to Restore Wool’s Water Resistance: 手順 6、 2の画像 1 How to Restore Wool’s Water Resistance: 手順 6、 2の画像 2
    • Mix 4 tablespoons of emulsified lanolin into 2 liters of water.
  7. How to Restore Wool’s Water Resistance: 手順 7、 2の画像 1 How to Restore Wool’s Water Resistance: 手順 7、 2の画像 2
    • Add the articles and squeeze to saturate.
    • Weight the articles with a heavy glass or a dish.
    • Leave to soak for 30 minutes.
  8. How to Restore Wool’s Water Resistance: 手順 8、 2の画像 1 How to Restore Wool’s Water Resistance: 手順 8、 2の画像 2
    • Pull the articles out of the lanolin bath and gently squeeze out excess water.
  9. How to Restore Wool’s Water Resistance: 手順 9、 1の画像 1
    • Lay flat to dry with a clean towel beneath the items.
    • Do not line dry. It can cause wool to stretch and lose shape.
    • Avoid direct sunlight or direct heat when drying.
ゴール
作成者
1人の作成者と共同作成されました。
Yuliya S
メンバー登録日: 01/17/22
169 ポイント
1ガイドが承認済み
チーム
York University, Team 1-26, O'Regan Winter 2022 York University, Team 1-26, O'Regan Winter 2022人のメンバー
YORK-O'REGAN-W22S1G26
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 21
今までの合計 494
