メインコンテンツにスキップ
How to Restore Jordan Midsoles
必要な工具と部品
  1. How to Restore Jordan Midsoles, How to Restore Jordan Midsoles: 手順 1、 1の画像 1
    • Grab the pair of Jordans you would like to repaint and wipe the midsole with a toothbrush or cotton ball to remove any dirt or dust (midsoles are already clean in this picture).
  2. How to Restore Jordan Midsoles: 手順 2、 1の画像 1
    • Using a metal file, carefully scratch off the paint closest to the leather.
  3. How to Restore Jordan Midsoles: 手順 3、 1の画像 1
    • Wet a cotton ball with acetone and lightly scrub the leftover paint until the surface is smooth and most or all the paint is removed.
    • I recommend using rubber gloves to protect your skin from the acetone, but it's not necessary.
  4. How to Restore Jordan Midsoles: 手順 4、 1の画像 1
    • Remove any dust, dirt, and excess paint with your fingers or cotton balls and water.
  5. How to Restore Jordan Midsoles: 手順 5、 1の画像 1
    • Carefully place painter's tape along the edges of the part of the shoe you would like to paint.
  6. How to Restore Jordan Midsoles: 手順 6、 3の画像 1 How to Restore Jordan Midsoles: 手順 6、 3の画像 2 How to Restore Jordan Midsoles: 手順 6、 3の画像 3
    • Grab your paint and paint brush and thinly coat the desired area.
  7. How to Restore Jordan Midsoles: 手順 7、 1の画像 1
    • Wait until your paint dries and apply another coat. Repeat this step 2-4 more times or until you're content with the shade of your color. This picture depicts the shade of white after 5 coats.
    • For best results, wait 24 hours between each paint coat.
  8. How to Restore Jordan Midsoles: 手順 8、 3の画像 1 How to Restore Jordan Midsoles: 手順 8、 3の画像 2 How to Restore Jordan Midsoles: 手順 8、 3の画像 3
    • After applying your final coat, allow 24-48 hours for the paint to dry before wearing. Once your paint is dry, remove the tape and you're good to go!
ゴール
15 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kevin Wong
メンバー登録日: 09/29/15
731 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-6, Green Fall 2015 Cal Poly, Team 17-6, Green Fall 2015人のメンバー
CPSU-GREEN-F15S17G6
3 メンバー
1のガイドは作成済み
2 件のコメント
this is a really bad explanation. You should get a life, because you clearly suck at this
William Roberts - 返信
I just finished my first pair of restored J’s by following the OP instructions. It does take some time and precision work, and patience, but just WOW my Jordans look brand new! (I created a profile but for some reason I can’t log in, ..?) Thanks again OP for this awesome and easy to follow tutorial!
Inigo Montoya - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 26
過去 30 日: 94
今までの合計 28,610
