メインコンテンツにスキップ
How to Restore Foggy Car Headlights
必要な工具と部品
  1. How to Restore Foggy Car Headlights, How to Restore Foggy Car Headlights: 手順 1、 3の画像 1 How to Restore Foggy Car Headlights, How to Restore Foggy Car Headlights: 手順 1、 3の画像 2 How to Restore Foggy Car Headlights, How to Restore Foggy Car Headlights: 手順 1、 3の画像 3
    • Place masking tape around the perimeter of the headlights to protect your vehicle's paint.
  2. How to Restore Foggy Car Headlights: 手順 2、 3の画像 1 How to Restore Foggy Car Headlights: 手順 2、 3の画像 2 How to Restore Foggy Car Headlights: 手順 2、 3の画像 3
    • Soak your 1000, 1500, and 2000 grit sandpaper in a bucket of clean water.
    • Once the edges begin to roll, the sandpaper is ready to use.
  3. How to Restore Foggy Car Headlights: 手順 3、 3の画像 1 How to Restore Foggy Car Headlights: 手順 3、 3の画像 2 How to Restore Foggy Car Headlights: 手順 3、 3の画像 3
    • Use wet 1000 grit sandpaper and light pressure to sand the plastic in circular patterns. When you notice that the small scratches look identical across the entire headlight, sand horizontally until all the small scratches appear horizontal.
    • Use a spray-bottle filled with water to keep the sandpaper and the headlight wet throughout the entire sanding process. Dry sanding can damage plastic.
    • Repeat the process with 1500, then 2000 grit sandpaper.
  4. How to Restore Foggy Car Headlights: 手順 4、 3の画像 1 How to Restore Foggy Car Headlights: 手順 4、 3の画像 2 How to Restore Foggy Car Headlights: 手順 4、 3の画像 3
    • Thoroughly dry the headlights.
    • Use a microfiber cloth and moderate pressure to apply a thin layer of carnauba wax to the entire surface of the headlights.
    • Work the wax into the plastic using small circular motions.
    • Wait until the wax dries to a haze, then buff it off with a clean microfiber towel.
  5. How to Restore Foggy Car Headlights: 手順 5、 3の画像 1 How to Restore Foggy Car Headlights: 手順 5、 3の画像 2 How to Restore Foggy Car Headlights: 手順 5、 3の画像 3
    • Use 70% isopropyl alcohol and paper towels to remove any residue on the headlights.
    • It is very important remove any wax residue, as it will prevent the clear coat from properly binding.
  6. How to Restore Foggy Car Headlights: 手順 6、 3の画像 1 How to Restore Foggy Car Headlights: 手順 6、 3の画像 2 How to Restore Foggy Car Headlights: 手順 6、 3の画像 3
    • Tape down newspaper or plastic bags at least a foot in radius surrounding the headlights, to avoid damaging your vehicle's paint during the clear coat application.
    • Make sure there are no uncovered gaps.
  7. How to Restore Foggy Car Headlights: 手順 7、 3の画像 1 How to Restore Foggy Car Headlights: 手順 7、 3の画像 2 How to Restore Foggy Car Headlights: 手順 7、 3の画像 3
    • Make sure the headlights are completely dry and that it isn't going to rain/snow in the near future, or that you have a well-ventilated, covered space to work in.
    • Shake the clear coat well and apply a thin coat evenly across the entire headlight, using long, quick strokes to avoid pooling.
    • Wait for the clear coat to fully dry before applying the next coat. Apply at least two coats for better results.
    • Read the product label and follow the manufacturer's application directions
    • Do not apply clear coat in poorly ventilated conditions.
  8. How to Restore Foggy Car Headlights: 手順 8、 1の画像 1
    • Repeat Steps 3 and 4 to achieve the best result, using only 2,000 grit sandpaper and very light pressure to smooth the clear coat.
終わりに
Enjoy your crystal-clear headlights!
6 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Javier Badillo
メンバー登録日: 03/18/22
253 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 31
過去 30 日: 206
今までの合計 4,980
