メインコンテンツにスキップ
How to Reshape a Warped Nail Polish Brush
必要な工具と部品
  1. How to Reshape a Warped Nail Polish Brush, How to Reshape a Warped Nail Polish Brush: 手順 1、 2の画像 1 How to Reshape a Warped Nail Polish Brush, How to Reshape a Warped Nail Polish Brush: 手順 1、 2の画像 2
    • Remove the nail polish brush from bottle.
    • Wrap the bottle of nail polish with aluminum foil to prevent the polish from drying.
  2. How to Reshape a Warped Nail Polish Brush: 手順 2、 2の画像 1 How to Reshape a Warped Nail Polish Brush: 手順 2、 2の画像 2
    • Wipe the brush clean with a paper towel.
  3. How to Reshape a Warped Nail Polish Brush: 手順 3、 2の画像 1 How to Reshape a Warped Nail Polish Brush: 手順 3、 2の画像 2
    • Clean the brush in small amount of 100% pure acetone in a glass bowl.
    • DO NOT USE ANY OTHER TYPE OF CONTAINER MATERIALS OTHER THAN GLASS or PORCELAIN FOR ACETONE. Acetone is a chemical that will damage the plastic’s surface by softening it, smearing it, or even dissolving the plastic.
  4. How to Reshape a Warped Nail Polish Brush: 手順 4、 1の画像 1
    • Blow-dry the brush on medium-low heat from brush base to tip for 30-90 seconds.
  5. How to Reshape a Warped Nail Polish Brush: 手順 5、 3の画像 1 How to Reshape a Warped Nail Polish Brush: 手順 5、 3の画像 2 How to Reshape a Warped Nail Polish Brush: 手順 5、 3の画像 3
    • Reshape the warm bristles by hand or press in a book, rotating as needed.
    • You can reheat the bristles if they are not yet flattened into the desired shape.
終わりに
Test a swatch on a piece of paper to check the shape of the brush with the nail polish. If the shape is not yet to its desired form, restart the guide to reshape the brush.
作成者
1人の作成者と共同作成されました。
Michelle Nguyen
メンバー登録日: 09/28/22
121 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-12, Friess Fall 2022 University of North Texas, Team 1-12, Friess Fall 2022人のメンバー
UNT-FRIESS-F22S1G12
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 45
今までの合計 1,172
