この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
On the off chance that you've rolled out certain improvements to the settings of your Dell office printer and now the unit won't work legitimately, it tends to be hard to follow your means and return the printer to its past state. For a situation like this, it may be simpler to complete an industrial facility reset on the printer, which reestablishes all the first settings from when the unit was delivered from the processing plant. In the event that your printer is arranged, you may probably reset it utilizing its Web support; else, you'll have to utilize the on-board menu board or press a specific key blend on the printer to reset it
Follow these steps for Reset Dell Printer Factory setting and cartridge
Open a Web program and type the printer's IP address to get to its Web comfort. Your system director ought to have the printer's IP address, or you may almost certainly discover it by printing an arrangement page. Normally, squeezing and holding the "Proceed" catch will produce the page.
Sign in to the comfort - your system director ought to have this data - and search for the "Reset Print Server" alternative, normally situated in a segment marked "Printer settings" or comparable.
Shut the printer off and unplug it. Leave the printer unplugged for five minutes. Fitting it back in and turn it on.
Addition the refilled inkjet cartridge in your Dell printer and turn off the printer for no less than five seconds.
Turn on the printer and you'll see a Dell print utility discourse window open on your PC screen. The window shows a notice that your print level is underneath the base dimension. In the event that this window doesn't dispatch naturally, open a report and endeavor to print. .
Uncheck the "Total a-Print" check box. Just underneath it you'll see the "Don't Display This Dialog Again" box; check it.
Click on OK or "Keep Printing," contingent upon whether you're on the startup cautioning page or in the event that you endeavored to print a report, individually. This resets your ink level.
3 件のコメント
Hi, my Dell printer won't let me print and will not connect to the internet. Any ideas now?
try resetting your printer
