メインコンテンツにスキップ
How to Reset your Dell Printer Factory Setting and Cartridge
  1. How to Reset your Dell Printer Factory Setting and Cartridge, Reset Dell Printer to Factory Setting: 手順 1、 1の画像 1
    • Open a Web program and type the printer's IP address to get to its Web comfort. Your system director ought to have the printer's IP address, or you may almost certainly discover it by printing an arrangement page. Normally, squeezing and holding the "Proceed" catch will produce the page.
    • Sign in to the comfort - your system director ought to have this data - and search for the "Reset Print Server" alternative, normally situated in a segment marked "Printer settings" or comparable.
    • Shut the printer off and unplug it. Leave the printer unplugged for five minutes. Fitting it back in and turn it on.
  2. How to Reset your Dell Printer Factory Setting and Cartridge, Reset your Dell Printer Cartridge: 手順 2、 1の画像 1
    • Addition the refilled inkjet cartridge in your Dell printer and turn off the printer for no less than five seconds.
    • Turn on the printer and you'll see a Dell print utility discourse window open on your PC screen. The window shows a notice that your print level is underneath the base dimension. In the event that this window doesn't dispatch naturally, open a report and endeavor to print. .
    • Uncheck the "Total a-Print" check box. Just underneath it you'll see the "Don't Display This Dialog Again" box; check it.
    • Click on OK or "Keep Printing," contingent upon whether you're on the startup cautioning page or in the event that you endeavored to print a report, individually. This resets your ink level.
終わりに
作成者
2人の作成者と共同で作成されました。
Sofia james
メンバー登録日: 11/22/18
141 ポイント
1ガイドが承認済み
3 件のコメント
Hi, my Dell printer won't let me print and will not connect to the internet. Any ideas now?
Dakota Fleming - 返信
try resetting your printer
Claude Rixon - 返信
Hello can dell 3460dn cartridge be resetted ?
musa King - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 57
今までの合計 3,730
