メインコンテンツにスキップ
How to Reset the Mainboard in your Framework Desktop
  1. How to Reset the Mainboard in your Framework Desktop, Power down your Desktop: 手順 1、 2の画像 1 How to Reset the Mainboard in your Framework Desktop, Power down your Desktop: 手順 1、 2の画像 2
    • Before you begin repairs, shut down your Desktop from the operating system and unplug it.
    • Wait one minute before continuing to allow your Desktop to fully power down.
  2. How to Reset the Mainboard in your Framework Desktop, Remove the Handle: 手順 2、 3の画像 1 How to Reset the Mainboard in your Framework Desktop, Remove the Handle: 手順 2、 3の画像 2 How to Reset the Mainboard in your Framework Desktop, Remove the Handle: 手順 2、 3の画像 3
    • If you installed the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Rotate the Handle's screw threads counterclockwise on both sides until it comes free.
    • Remove the Handle.
  3. How to Reset the Mainboard in your Framework Desktop, Remove the Top Panel screws: 手順 3、 3の画像 1 How to Reset the Mainboard in your Framework Desktop, Remove the Top Panel screws: 手順 3、 3の画像 2 How to Reset the Mainboard in your Framework Desktop, Remove the Top Panel screws: 手順 3、 3の画像 3
    • Use your finger to lift up the two D-rings on the Top Panel screws.
  4. How to Reset the Mainboard in your Framework Desktop: 手順 4、 3の画像 1 How to Reset the Mainboard in your Framework Desktop: 手順 4、 3の画像 2 How to Reset the Mainboard in your Framework Desktop: 手順 4、 3の画像 3
    • Use your fingers to twist the screw counter-clockwise and loosen it.
    • Remove the Top Panel screw.
  5. How to Reset the Mainboard in your Framework Desktop: 手順 5、 3の画像 1 How to Reset the Mainboard in your Framework Desktop: 手順 5、 3の画像 2 How to Reset the Mainboard in your Framework Desktop: 手順 5、 3の画像 3
    • Repeat the same procedure for the other Top Panel screw.
  6. How to Reset the Mainboard in your Framework Desktop, Remove the Top Panel: 手順 6、 3の画像 1 How to Reset the Mainboard in your Framework Desktop, Remove the Top Panel: 手順 6、 3の画像 2 How to Reset the Mainboard in your Framework Desktop, Remove the Top Panel: 手順 6、 3の画像 3
    • Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
    • If you're having a hard time gripping the Top Panel, use the screw holes to get a better handhold.
    • Lift the Top Panel off the chassis and remove it.
  7. How to Reset the Mainboard in your Framework Desktop, Lay down the Desktop: 手順 7、 2の画像 1 How to Reset the Mainboard in your Framework Desktop, Lay down the Desktop: 手順 7、 2の画像 2
    • Lay down the Desktop on its right side.
  8. How to Reset the Mainboard in your Framework Desktop, Reset the Mainboard: 手順 8、 2の画像 1 How to Reset the Mainboard in your Framework Desktop, Reset the Mainboard: 手順 8、 2の画像 2
    • Press the white button labeled "CMOS RESET" next to the APU Fan connector and hold for 10 seconds.
  9. How to Reset the Mainboard in your Framework Desktop, Reposition the Desktop: 手順 9、 2の画像 1 How to Reset the Mainboard in your Framework Desktop, Reposition the Desktop: 手順 9、 2の画像 2
    • Lift the Desktop so it stands upright on your work surface.
  10. How to Reset the Mainboard in your Framework Desktop, Install the Top Panel: 手順 10、 3の画像 1 How to Reset the Mainboard in your Framework Desktop, Install the Top Panel: 手順 10、 3の画像 2 How to Reset the Mainboard in your Framework Desktop, Install the Top Panel: 手順 10、 3の画像 3
    • Orient the Top Panel so its arrow is pointing towards the rear of the computer.
    • While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
    • There should be a small gap between the Top Panel and the front of the Desktop.
    • Lay the Top Panel flat on the chassis to align the remaining clips.
  11. How to Reset the Mainboard in your Framework Desktop: 手順 11、 2の画像 1 How to Reset the Mainboard in your Framework Desktop: 手順 11、 2の画像 2
    • While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
  12. How to Reset the Mainboard in your Framework Desktop, Install the Handle: 手順 12、 2の画像 1 How to Reset the Mainboard in your Framework Desktop, Install the Handle: 手順 12、 2の画像 2
    • If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Place the Handle over the Top Panel screw holes.
    • While holding the Handle in place, twist the screw threads on both sides clockwise until they're snug on the Top Panel.
  13. How to Reset the Mainboard in your Framework Desktop, Install the top panel screws: 手順 13、 3の画像 1 How to Reset the Mainboard in your Framework Desktop, Install the top panel screws: 手順 13、 3の画像 2 How to Reset the Mainboard in your Framework Desktop, Install the top panel screws: 手順 13、 3の画像 3
    • Insert the top panel screw into its hole and twist clockwise until it feels snug.
  14. How to Reset the Mainboard in your Framework Desktop: 手順 14、 3の画像 1 How to Reset the Mainboard in your Framework Desktop: 手順 14、 3の画像 2 How to Reset the Mainboard in your Framework Desktop: 手順 14、 3の画像 3
    • Repeat the same procedure for the other top panel screw.
  15. How to Reset the Mainboard in your Framework Desktop: 手順 15、 3の画像 1 How to Reset the Mainboard in your Framework Desktop: 手順 15、 3の画像 2 How to Reset the Mainboard in your Framework Desktop: 手順 15、 3の画像 3
    • Use your finger to close the two D-rings on the top panel screws.
  16. How to Reset the Mainboard in your Framework Desktop, Plug in the Desktop: 手順 16、 2の画像 1 How to Reset the Mainboard in your Framework Desktop, Plug in the Desktop: 手順 16、 2の画像 2
    • Plug the Desktop back in.
    • Turn on your Desktop—it should boot up normally. If your BIOS settings haven't changed, or if you're still experiencing issues, repeat the Mainboard reset procedure.
終わりに
If you need help, contact Framework support.
ある他の人がこのガイドを完成しました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
213,515 ポイント
1,040のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 32
過去 30 日: 115
今までの合計 365
