メインコンテンツにスキップ
How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable
必要な工具と部品
  1. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable, How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 手順 1、 2の画像 1 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable, How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 手順 1、 2の画像 2
    • Carefully remove the plastic cover and set aside.
  2. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 手順 2、 3の画像 1 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 手順 2、 3の画像 2 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 手順 2、 3の画像 3
    • Remove the pad if there is one.
    • Spin the turntable until the belt and drive motor can be seen through a hole.
    • Gently pull the belt off of the motor, and make sure that the belt doesn’t bend or flip over.
    • Take off the turntable platter and set aside.
  3. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 手順 3、 3の画像 1 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 手順 3、 3の画像 2 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 手順 3、 3の画像 3
    • Remove the single screw from the middle white gear with a Phillips #00 screwdriver.
    • Have a cup or bin so you don’t lose the screw!
    • Gently pull the gear out, revealing the automatic mechanism.
  4. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 手順 4、 3の画像 1 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 手順 4、 3の画像 2 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 手順 4、 3の画像 3
    • Push the metal part away from the center. It should click into place.
    • Push the small metal part back to the center, towards the gear axle.
    • Push the metal part inward, close to the gear’s mounting point.
  5. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 手順 5、 1の画像 1
    • Replace the gear, making sure that the the metal latch on the gear is pushed back.
    • The central shaft should spin freely without hooking the gear.
    • Don't forget to put the band back on the drive motor when reassembling.
終わりに
作成者
2人の作成者と共同で作成されました。
Devin Hoopes
メンバー登録日: 09/08/21
121 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 80
今までの合計 2,323
