メインコンテンツにスキップ
How to Replace the Windshield Wiper Blade for Honda Spike 2006
必要な工具と部品
  1. How to Replace the Windshield Wiper Blade for Honda Spike 2006, Lift the Wiper Arm: 手順 1、 2の画像 1 How to Replace the Windshield Wiper Blade for Honda Spike 2006, Lift the Wiper Arm: 手順 1、 2の画像 2
    • Grab the windshield wiper at the base and lift in a counter-clockwise motion around the hinge, lifting the blade from the window.
  2. How to Replace the Windshield Wiper Blade for Honda Spike 2006, Rotate the Blade Assembly: 手順 2、 2の画像 1 How to Replace the Windshield Wiper Blade for Honda Spike 2006, Rotate the Blade Assembly: 手順 2、 2の画像 2
    • Rotate the wiper blade assembly so the replaceable blade faces outward.
  3. How to Replace the Windshield Wiper Blade for Honda Spike 2006, Remove the Retaining Clasp: 手順 3、 2の画像 1 How to Replace the Windshield Wiper Blade for Honda Spike 2006, Remove the Retaining Clasp: 手順 3、 2の画像 2
    • Remove the retaining clasp on the right edge of the blade.
    • The clasp is always on the rightmost edge of each blade.
  4. How to Replace the Windshield Wiper Blade for Honda Spike 2006, Removing the Wiper Blade: 手順 4、 3の画像 1 How to Replace the Windshield Wiper Blade for Honda Spike 2006, Removing the Wiper Blade: 手順 4、 3の画像 2 How to Replace the Windshield Wiper Blade for Honda Spike 2006, Removing the Wiper Blade: 手順 4、 3の画像 3
    • After removing the clasp, pull the blade from the wiper arm.
  5. How to Replace the Windshield Wiper Blade for Honda Spike 2006, Insert the Wiper Blade: 手順 5、 2の画像 1 How to Replace the Windshield Wiper Blade for Honda Spike 2006, Insert the Wiper Blade: 手順 5、 2の画像 2
    • Insert the new blade by sliding it back into the slots on the wiper arm.
  6. How to Replace the Windshield Wiper Blade for Honda Spike 2006, Reattach the Retaining Clip: 手順 6、 1の画像 1
    • Reattach the clasp by sliding it back over the edge of the wiper blade.
  7. How to Replace the Windshield Wiper Blade for Honda Spike 2006, Rotate the Wiper Blade: 手順 7、 2の画像 1 How to Replace the Windshield Wiper Blade for Honda Spike 2006, Rotate the Wiper Blade: 手順 7、 2の画像 2
    • Return the windshield wiper blade back to its original orientation.
  8. How to Replace the Windshield Wiper Blade for Honda Spike 2006, Lower the Wiper Arm: 手順 8、 2の画像 1 How to Replace the Windshield Wiper Blade for Honda Spike 2006, Lower the Wiper Arm: 手順 8、 2の画像 2
    • Rotate the wiper arm clockwise around the hinge until it rests on the windshield.
ゴール
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Yota Higuchi
メンバー登録日: 06/02/17
154 ポイント
1ガイドが承認済み
チーム
Arkansas State University, Team S1-G9, Chamberlain Summer 2017 Arkansas State University, Team S1-G9, Chamberlain Summer 2017人のメンバー
ARSU-CHAMBERLAIN-SU17S1G9
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 28
今までの合計 743
