メインコンテンツにスキップ
How to Replace the Wax Ring on a Toilet
必要な工具と部品
  1. How to Replace the Wax Ring on a Toilet, Wax Ring: 手順 1、 1の画像 1
    • Turn off the water.
    • You do not want to forget this step.
  2. How to Replace the Wax Ring on a Toilet: 手順 2、 1の画像 1
    • Disconnect the hose from the toilet by unscrewing the white plastic connector.
    • Excess water will spill out of this pipe, so have a bucket or rag nearby to catch it!
  3. How to Replace the Wax Ring on a Toilet: 手順 3、 1の画像 1
    • Remove the plastic bolt protectors on either side of the base of the toilet.
    • Using a wrench, remove the nuts and washers from the bottom of the toilet where it's bolted to the floor.
    • Lift the toilet up from the floor.
    • Use caution when lifting it, it's going to be heavy!
    • Set the toilet off to the side.
  4. How to Replace the Wax Ring on a Toilet: 手順 5、 1の画像 1
    • Remove the old wax ring and any debris from the toilet pipe in the floor where the toilet was, being sure not to let any debris fall down the pipe.
    • It may be nice to wear gloves for this step, as the old wax ring will be a bit dirty.
  5. How to Replace the Wax Ring on a Toilet: 手順 6、 1の画像 1
    • Place new ring in the proper position for your toilet to rest on.
    • Carefully position the toilet back over the hole, paying attention to the bolts.
  6. How to Replace the Wax Ring on a Toilet: 手順 7、 1の画像 1
    • Tighten the nuts and bolts on each side of the toilet and replace the bolt-protectors.
終わりに
Make sure you wash your hands!
作成者
2人の作成者と共同で作成されました。
Ahna Hensley
メンバー登録日: 01/18/21
145 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 88
今までの合計 1,938
