はじめに
This guide details the process to replace the rear wheel of a Segway Ninebot ES4. Having tires with good grip is vital for safe use, so it is necessary to replace the wheels on scooters when they are worn.
必要な工具と部品
Place the scooter on its side and locate the two access screw holes.
Use a flathead screwdriver to remove the protective inserts.
With that, you've replaced the rear wheel of your Segway Ninebot ES4! Happy scootering!
ある他の人がこのガイドを完成しました。
