メインコンテンツにスキップ
How to Replace the GPU on a Dell OptiPlex 9010
必要な工具と部品
  1. How to Replace the GPU on a Dell OptiPlex 9010, Graphics Card: 手順 1、 3の画像 1 How to Replace the GPU on a Dell OptiPlex 9010, Graphics Card: 手順 1、 3の画像 2 How to Replace the GPU on a Dell OptiPlex 9010, Graphics Card: 手順 1、 3の画像 3
    • Before getting started, make sure to shut down and unplug all cables from your computer.
    • Place the computer on a flat surface.
  2. How to Replace the GPU on a Dell OptiPlex 9010: 手順 2、 2の画像 1 How to Replace the GPU on a Dell OptiPlex 9010: 手順 2、 2の画像 2
    • Lay the computer on its side, on the flat surface.
    • Use a Phillips #2 screwdriver to remove any screws holding the side panel in place.
    • Use the handle on the side panel to pull it up to remove it.
  3. How to Replace the GPU on a Dell OptiPlex 9010: 手順 3、 3の画像 1 How to Replace the GPU on a Dell OptiPlex 9010: 手順 3、 3の画像 2 How to Replace the GPU on a Dell OptiPlex 9010: 手順 3、 3の画像 3
    • Grip the side panel with both hands to fully remove it. This will give you a complete look into the internal hardware.
    • Be sure to touch the metal casing inside to ground yourself. Otherwise, you might accidentally damage the components from the static electricity your body builds up.
  4. How to Replace the GPU on a Dell OptiPlex 9010: 手順 4、 3の画像 1 How to Replace the GPU on a Dell OptiPlex 9010: 手順 4、 3の画像 2 How to Replace the GPU on a Dell OptiPlex 9010: 手順 4、 3の画像 3
    • Push down on the release tab on the card retention latch to free the existing (old) graphics card.
  5. How to Replace the GPU on a Dell OptiPlex 9010: 手順 5、 3の画像 1 How to Replace the GPU on a Dell OptiPlex 9010: 手順 5、 3の画像 2 How to Replace the GPU on a Dell OptiPlex 9010: 手順 5、 3の画像 3
    • Unlatch the PCIE clip. Gently remove the existing graphics card to make sure there are no cables caught.
  6. How to Replace the GPU on a Dell OptiPlex 9010: 手順 6、 3の画像 1 How to Replace the GPU on a Dell OptiPlex 9010: 手順 6、 3の画像 2 How to Replace the GPU on a Dell OptiPlex 9010: 手順 6、 3の画像 3
    • Now grab your replacement GPU (graphics card).
  7. How to Replace the GPU on a Dell OptiPlex 9010: 手順 7、 3の画像 1 How to Replace the GPU on a Dell OptiPlex 9010: 手順 7、 3の画像 2 How to Replace the GPU on a Dell OptiPlex 9010: 手順 7、 3の画像 3
    • Add or remove expansion slot covers based on the number of slots your new graphics card requires.
  8. How to Replace the GPU on a Dell OptiPlex 9010: 手順 8、 2の画像 1 How to Replace the GPU on a Dell OptiPlex 9010: 手順 8、 2の画像 2
    • Firmly place the new GPU on the bus (into the slot). Reclip the PCIE clamp to hold it into place.
  9. How to Replace the GPU on a Dell OptiPlex 9010: 手順 9、 3の画像 1 How to Replace the GPU on a Dell OptiPlex 9010: 手順 9、 3の画像 2 How to Replace the GPU on a Dell OptiPlex 9010: 手順 9、 3の画像 3
    • Check to make sure the new GPU card is properly positioned to fit with the screw holes and expansion slots.
  10. How to Replace the GPU on a Dell OptiPlex 9010: 手順 10、 2の画像 1 How to Replace the GPU on a Dell OptiPlex 9010: 手順 10、 2の画像 2
    • Screw in any 6-32 Phillips screws (any that are from 1/4 to 1/2 inch long) with your Phillips screwdriver to properly secure your new GPU card.
  11. How to Replace the GPU on a Dell OptiPlex 9010: 手順 11、 3の画像 1 How to Replace the GPU on a Dell OptiPlex 9010: 手順 11、 3の画像 2 How to Replace the GPU on a Dell OptiPlex 9010: 手順 11、 3の画像 3
    • Pull up on the release tab on the card retention latch to secure the card.
  12. How to Replace the GPU on a Dell OptiPlex 9010: 手順 12、 2の画像 1 How to Replace the GPU on a Dell OptiPlex 9010: 手順 12、 2の画像 2
    • Line the side panel up with the clamps and push it down to reattach the panel.
  13. How to Replace the GPU on a Dell OptiPlex 9010: 手順 13、 2の画像 1 How to Replace the GPU on a Dell OptiPlex 9010: 手順 13、 2の画像 2
    • Use your Phillips #2 screwdriver to replace the screws and secure the side panel.
ゴール
作成者
5人の作成者と共同で作成されました。
Michael Cortez
メンバー登録日: 09/19/22
217 ポイント
1ガイドが承認済み
チーム
York University, Team A-10, Morris Fall 2022 York University, Team A-10, Morris Fall 2022人のメンバー
YORK-MORRIS-F22SAG10
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 63
今までの合計 860
