この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If you try to use the ice dispenser on a GE Refrigerator (SN:GSL25IGXL LS), but the ice is getting stuck in the refrigerator door, this could be a sign that the solenoid is bad.
The solenoid is connected to an insulated flap that will open and close when using the ice dispenser.
Before using this guide, check the flap where the ice is dispensed to make sure there is no debris. If there is something blocking the flap from opening , remove the debris and try to use the ice dispenser.
Before starting, make sure all power is shut off, you will be touching a circuit board.
必要な工具と部品
Unplug the refrigerator to turn off the power. You can also turn off the power using the breaker panel.
