この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
A leaky water key can make playing difficult and a horn sound strange. Instrument repair professionals can fix leaky water keys, but often times all a water key needs is a new cork—an easy fix you can do at home. Water key corks are inexpensive and available at most music stores and online, but a wine cork cut to the right size will work in a pinch.
必要な工具と部品
If your water key still leaks after replacing the cork, it may need to be bent back into place or may need a new spring. See an instrument repair professional or another online guide for help with this.
6 の人々がこのガイドを完成させました。
コメント 1 件
Let me suggest that there is an easier way to a permanent solution for leaky corks - remove the water automatically by installing a JoyKey. No more leaking corks, no moving parts, no sptings or having to manually deal with water.
For more information:
www.thejoykey.com and http://thejoykey.com/wp-content/uploads/...
