メインコンテンツにスキップ
How to Replace the Bail Spring in a Spinning Reel
必要な工具と部品
  1. How to Replace the Bail Spring in a Spinning Reel, Spinning Reel Bail Spring Replacement for south bend 840: 手順 1、 1の画像 1
    • Remove the screw that holds the base of the bail arm to the reel with a Phillips #1 screwdriver.
  2. How to Replace the Bail Spring in a Spinning Reel: 手順 2、 2の画像 1 How to Replace the Bail Spring in a Spinning Reel: 手順 2、 2の画像 2
    • Slowly pull the base of the bail arm away from the reel in a twisting motion to separate the two parts.
  3. How to Replace the Bail Spring in a Spinning Reel: 手順 3、 1の画像 1
    • Remove the worn out bail spring by pushing down on the spring, then pulling outward away from the reel.
  4. How to Replace the Bail Spring in a Spinning Reel: 手順 4、 3の画像 1 How to Replace the Bail Spring in a Spinning Reel: 手順 4、 3の画像 2 How to Replace the Bail Spring in a Spinning Reel: 手順 4、 3の画像 3
    • Replace the worn out bail spring by separating the pin from the spring. Then place the original pin inside of the new spring.
  5. How to Replace the Bail Spring in a Spinning Reel: 手順 5、 2の画像 1 How to Replace the Bail Spring in a Spinning Reel: 手順 5、 2の画像 2
    • Place the new bail spring and pin back in the spring slot. Lightly push down on the spring to allow it to sit in its original position.
  6. How to Replace the Bail Spring in a Spinning Reel: 手順 6、 1の画像 1
    • Line the bail back up with the reel, ensuring all holes align with each other. Lightly squeeze the bail and reel together to allow the two pieces to snap back together.
  7. How to Replace the Bail Spring in a Spinning Reel: 手順 7、 1の画像 1
    • Insert the same screw used in Step 1 back into the hole and firmly screw it in.
終わりに
By replacing the spring, the entire open bail reel is saved from turning into unnecessary garbage that is harmful to the environment. Happy Fishing!
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Zach Lyles
メンバー登録日: 02/20/19
177 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S2-G7, Baddour Spring 2019 University of Memphis, Team S2-G7, Baddour Spring 2019人のメンバー
UM-BADDOUR-S19S2G7
3 メンバー
2のガイドは作成済み
コメント 1 件
Thanks for the clear pictures and instructions. Your tutorial was helpful along with a YouTube video on bail repair of a very similar spinning reel I have.
Steve McCormick - 返信
コメントを追加
統計データ:
過去 24時間: 17
過去 7 日: 146
過去 30 日: 550
今までの合計 32,681
