メインコンテンツにスキップ
How to Replace or Clean a Macbook Key
必要な工具と部品
  1. How to Replace or Clean a Macbook Key, How to Replace or Clean a Macbook Key: 手順 1、 1の画像 1
    • Stick your finger underneath the key. Gently pry it up.
    • You may need a spudger or flathead screwdriver to remove the key.
  2. How to Replace or Clean a Macbook Key: 手順 2、 1の画像 1
    • Now, carefully use your spudger or small flathead to, very gently, pry up the key mechanism, being careful not to damage it.
    • You should now clean the key using a Q-tip, and taking the key and mechanism and put it in water and dry it out. It's not too hard to put the mechanism back together again. Or use a can of compressed air.
  3. How to Replace or Clean a Macbook Key: 手順 3、 1の画像 1
    • Once you have removed and cleaned the key (or have not cleaned) take a close look at the key. There is a big hook on the right side, and two smaller hooks on the top left and bottom left.
  4. How to Replace or Clean a Macbook Key: 手順 4、 1の画像 1
    • Now what you want to do, is hold the mechanism flat side up. Put the mechanism into the hook on the right side. A spudger or small flathead might help.
  5. How to Replace or Clean a Macbook Key: 手順 5、 1の画像 1
    • Now pop in the two pins on the bottom left and top left into their hooks using a small spudger or flathead.
  6. How to Replace or Clean a Macbook Key: 手順 6、 1の画像 1
    • Now, take the key cap and pop it back on the computer.
    • When you put the key back on, press it a few times to make sure the mechanism doesn't come out.
    • Now test the keyboard, verifying that everything works.
終わりに
That was the guide on how to clean the keys on a MacBook.
18 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Brandon Sky Pimenta
メンバー登録日: 09/09/12
1,383 ポイント
1ガイドが承認済み
1件のガイドコメント
Awesome article about mac laptop key replacement
Andrew Mac
http://www.replacementlaptopkeys.com/
James lee - 返信
コメントを追加
統計データ:
過去 24時間: 21
過去 7 日: 115
過去 30 日: 618
今までの合計 76,370
