メインコンテンツにスキップ
How to Replace a Transition Strip (T Molding)
必要な工具と部品
  1. How to Replace a Transition Strip (T Molding), Transition Strip (T Molding): 手順 1、 1の画像 1
    • Measure the exact width of the doorway using a tape measure.
  2. How to Replace a Transition Strip (T Molding): 手順 2、 3の画像 1 How to Replace a Transition Strip (T Molding): 手順 2、 3の画像 2 How to Replace a Transition Strip (T Molding): 手順 2、 3の画像 3
    • Mark the T molding based on the doorway measure.
    • Cut the T molding using a sharp saw (table saw).
    • Cutting the T molding can be done for free at the place of purchase.
    • If you don't have access to a sharp saw, cut the T molding using a jigsaw and use sanding paper to soften the end.
  3. How to Replace a Transition Strip (T Molding): 手順 3、 3の画像 1 How to Replace a Transition Strip (T Molding): 手順 3、 3の画像 2 How to Replace a Transition Strip (T Molding): 手順 3、 3の画像 3
    • Remove the old T molding.
    • You can use a pry bar to loosen the T molding.
  4. How to Replace a Transition Strip (T Molding): 手順 4、 2の画像 1 How to Replace a Transition Strip (T Molding): 手順 4、 2の画像 2
    • Use a utility knife to remove all the glue or any material used to keep the old T molding in place.
    • You may use a scraper instead of a utility knife.
    • Clean up the area thoroughly.
  5. How to Replace a Transition Strip (T Molding): 手順 5、 1の画像 1
    • Apply the glue evenly to the gap.
  6. How to Replace a Transition Strip (T Molding): 手順 6、 3の画像 1 How to Replace a Transition Strip (T Molding): 手順 6、 3の画像 2 How to Replace a Transition Strip (T Molding): 手順 6、 3の画像 3
    • Insert the T molding into the gap.
    • Press the T molding firmly onto the ground.
    • No gap should exist between the T molding and the floorings.
  7. How to Replace a Transition Strip (T Molding): 手順 7、 2の画像 1 How to Replace a Transition Strip (T Molding): 手順 7、 2の画像 2
    • Tape the T molding onto the floor.
    • This step ensures the T molding stays in place until the glue dries.
    • Wait 24 hours for the glue to dry.
    • Remove the tapes.
終わりに
作成者
1人の作成者と共同作成されました。
Rojean Noorinayer
メンバー登録日: 05/12/21
145 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G19, Melo-Thaiss Summer 2021 York University, Team S1-G19, Melo-Thaiss Summer 2021人のメンバー
YORK-MELO-THAISS-SU21S1G19
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 36
過去 30 日: 176
今までの合計 3,570
