メインコンテンツにスキップ
How to Replace a Tail Light for a 2011-2015 Ford Explorer
必要な工具と部品
  1. How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: 手順 1、 2の画像 1 How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: 手順 1、 2の画像 2
    • Lift and open the rear cargo door.
  2. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 手順 2、 1の画像 1
    • Locate the two plastic screw covers that are adjacent to the rear light covers.
  3. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 手順 3、 1の画像 1
    • Using a flathead screwdriver, pry out both plastic screw covers.
  4. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 手順 4、 1の画像 1
    • Once covers are removed, there will be an 8 mm hex head screw located beneath each cover.
  5. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 手順 5、 1の画像 1
    • Using an 8 mm Deep Socket Wrench, remove both of the 20 mm (length) hex-head screws.
  6. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 手順 6、 2の画像 1 How to Replace a Tail Light for a 2011-2015 Ford Explorer: 手順 6、 2の画像 2
    • Gently pull the tail light cover from the car.
    • You may have to gently play with the cover by moving it back and forth in order to pry it loose form the car.
  7. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 手順 7、 1の画像 1
    • Once removed, the bulb sockets will be located on the inside portion of the tail light cover.
  8. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 手順 8、 1の画像 1
    • Turn the bulb socket about one quarter turn in a counterclockwise direction.
    • After it is turned, gently pull and remove the bulb socket from the tail light cover.
  9. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 手順 9、 1の画像 1
    • Gently remove the bulb from the bulb socket.
  10. How to Replace a Tail Light for a 2011-2015 Ford Explorer: 手順 10、 1の画像 1
    • Gently place the new bulb in the bulb socket.
終わりに
8 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Michael Lynch
メンバー登録日: 09/29/15
317 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015人のメンバー
CPSU-GREEN-F15S14G4
5 メンバー
16のガイドは作成済み
コメント 1 件
That's not the tail lights that is the turn signal and back up lights.
Djay Glass - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 23
過去 30 日: 109
今までの合計 22,046
