メインコンテンツにスキップ
How to Replace a Skateboard Deck
必要な工具と部品
  1. How to Replace a Skateboard Deck, Deck: 手順 1、 1の画像 1
    • Use the 3/8" socket to take off the nut
    • Use the phillips side to hold the screw in place.
    • Remove the nut
    • Repeat for all four nuts on the truck
    • Repeat for the second truck
  2. How to Replace a Skateboard Deck: 手順 2、 2の画像 1 How to Replace a Skateboard Deck: 手順 2、 2の画像 2
    • Remove both trucks from the board
    • Remove all 8 screws
  3. How to Replace a Skateboard Deck: 手順 3、 3の画像 1 How to Replace a Skateboard Deck: 手順 3、 3の画像 2 How to Replace a Skateboard Deck: 手順 3、 3の画像 3
    • Line up the grip with the board
    • Ensure it covers the entirety of the board and hangs over the edge
    • Peel the back off at one end enough to reveal the sticky side.
    • Expose about four inches
    • Attach the peeled side to one end of the board
    • Press the grip onto the board slowly and work your way across the board
    • Ensure that there is no air bubbles forming when applying the grip
  4. How to Replace a Skateboard Deck: 手順 4、 2の画像 1 How to Replace a Skateboard Deck: 手順 4、 2の画像 2
    • Use the phillips head screwdriver to trace the edge of the board
    • Ensure it can be seen all the way around the board
  5. How to Replace a Skateboard Deck: 手順 5、 1の画像 1
    • Trim the grip along the trace you made with the box cutter
    • Use long and smooth motions for straight trims
    • Trim up the jagged edges left on the grip on the edge of the board
  6. How to Replace a Skateboard Deck: 手順 6、 1の画像 1
    • Sand the edges with the left over grip
    • This is to ensure the grip fully applies to the board
  7. How to Replace a Skateboard Deck: 手順 7、 2の画像 1 How to Replace a Skateboard Deck: 手順 7、 2の画像 2
    • Poke a hole with the screw from the bottom of the deck
    • Remove the screw
    • Insert it through the top on the deck
    • Repeat for all 4 holes
    • Repeat on the opposite side with the other truck
  8. How to Replace a Skateboard Deck: 手順 8、 3の画像 1 How to Replace a Skateboard Deck: 手順 8、 3の画像 2 How to Replace a Skateboard Deck: 手順 8、 3の画像 3
    • Use the 3/8" socket to screw on the nut
    • The hangar should face outwards
    • Tighten them until they're snug
    • Overtightening can damage the deck
ゴール
作成者
1人の作成者と共同作成されました。
Dylan Norris
メンバー登録日: 10/06/22
157 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 2-12, Raign Fall 2022 University of North Texas, Team 2-12, Raign Fall 2022人のメンバー
UNT-RAIGN-F22S2G12
2 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 27
今までの合計 977
