メインコンテンツにスキップ
How to Replace a Screen Protector on an iPhone 12
必要な工具と部品
  1. How to Replace a Screen Protector on an iPhone 12, Screen Protector: 手順 1、 3の画像 1 How to Replace a Screen Protector on an iPhone 12, Screen Protector: 手順 1、 3の画像 2 How to Replace a Screen Protector on an iPhone 12, Screen Protector: 手順 1、 3の画像 3
    • If you already have a pre-existing screen protector, you will gently peel of your existing screen protector from the top of you iPhone.
    • If any small pieces of the screen protector are still attached to the phone, genlty peel the pieces off until no more pieces remain.
    • When the screen protector and the pieces are removed, you can dispose of it immediately or set it aside for disposal.
  2. How to Replace a Screen Protector on an iPhone 12: 手順 2、 3の画像 1 How to Replace a Screen Protector on an iPhone 12: 手順 2、 3の画像 2 How to Replace a Screen Protector on an iPhone 12: 手順 2、 3の画像 3
    • Grab the wet cloth from the pack and wipe the screen of the iPhone in order to remove any stain or mark left behind.
  3. How to Replace a Screen Protector on an iPhone 12: 手順 3、 2の画像 1 How to Replace a Screen Protector on an iPhone 12: 手順 3、 2の画像 2
    • With the LCD cloth, wipe and dry the screen of the phone to remove any small debris or dust.
  4. How to Replace a Screen Protector on an iPhone 12: 手順 4、 3の画像 1 How to Replace a Screen Protector on an iPhone 12: 手順 4、 3の画像 2 How to Replace a Screen Protector on an iPhone 12: 手順 4、 3の画像 3
    • Grab the dust sticker and apply it all around on the screen multiple times, until you covered all areas of the iPhone display.
  5. How to Replace a Screen Protector on an iPhone 12: 手順 5、 3の画像 1 How to Replace a Screen Protector on an iPhone 12: 手順 5、 3の画像 2 How to Replace a Screen Protector on an iPhone 12: 手順 5、 3の画像 3
    • Grab the screen protector and remove the plastic that's attached to the sticky part of the screen protector.
    • Align the new screen protector to the iPhone without touching the sticky part.
    • Press down on the screen protector from the top of the iPhone until you reach the bottom.
  6. How to Replace a Screen Protector on an iPhone 12: 手順 6、 3の画像 1 How to Replace a Screen Protector on an iPhone 12: 手順 6、 3の画像 2 How to Replace a Screen Protector on an iPhone 12: 手順 6、 3の画像 3
    • With the new screen protector on the phone, use the anti-bubble card to prevent bubbles from staying in between the iPhone and the screen protector.
    • Push the bubbles towards the edge of the iPhone until you see no more on the screen.
  7. How to Replace a Screen Protector on an iPhone 12: 手順 7、 1の画像 1
    • With the bubbles removed from the screen, the new screen protector for the iPhone 12 is now installed.
    • Dispose of any waste left after the installation.
終わりに
作成者
4人の作成者と共同で作成されました。
reveleszacatecas5
メンバー登録日: 10/24/23
145 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 8-3, Ribeiro Fall 2023 CSU Los Angeles, Team 8-3, Ribeiro Fall 2023人のメンバー
CSULA-RIBEIRO-F23S8G3
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 53
過去 30 日: 230
今までの合計 1,351
