はじめに
Many people can remember having experienced the times when their recliner decided that it doesn't want to work. They may have a recliner that does not recline at all or gets stuck in a reclined position and won't go back to the normal upright position. This guide is needed to help those who wish to save some time and money and perform the repair themselves. This replacement guide may require the assistance of another in order to maneuver the recliner into different positions to access the work area.
必要な工具と部品
Disconnect the power supply, power adapters, surge protectors, power strip and wall plug from the wall outlet.
3 の人々がこのガイドを完成させました。
6 件のコメント
can you do away with the motor and make it a manual
dick_linda - 返信
What is the most common problem when the recliner switch only works once and awhile? I took it all apart like you suggested but it still wont work. Is the switch on the side of the chair the most likely problem? How much does it cost to order a new switch from Steelcase?
I have Electric Massage Recliner Chair and buy-in last year. But unfortunately, my small child throws water on its remote control. Due to which it is not work properly. So if you have any repairing suggestions for that then please let me know. I am greatly thankful to you.
I bought a power lift recliner chair one year ago but power switch some time work and some time not work. I can not understand that what is the causes, can you suggest me for replace or fixing? I read your helpful article top to end. But I need help from you.
Check the cables to the switch under the chair and make sure they are not frayed, and make sure it's plugged into the motor.
My electric recliner quit working. As I plugged the cord into the power supply it sparks. I ordered a new power supply box and it sparks also. What could be the problem?
HI I am trying to source a replacement remote for a pulaski power recliner, with heat and massage facility. Do have any idea where I can get 2. Thanks.
dfinnegan148 - 返信
