メインコンテンツにスキップ
How to Replace a Nequare Cordless Vacuum S182 Filter
  1. How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: 手順 1、 2の画像 1 How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: 手順 1、 2の画像 2
    • Locate the black button to release the white motor unit from the rest of the vacuum cleaner.
  2. How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 2、 2の画像 1 How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 2、 2の画像 2
    • Hold down the black button to remove the white motor unit above and gently pull the motor unit upwards.
  3. How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 3、 2の画像 1 How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 3、 2の画像 2
    • Press the release button at the side of the dust canister to dispose of the debris.
    • Be sure to hold the the canister over a garbage can to avoid a spill.
  4. How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 4、 3の画像 1 How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 4、 3の画像 2 How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 4、 3の画像 3
    • After emptying the debris, hold down the black button, then twist and pull the canister out.
  5. How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 5、 2の画像 1 How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 5、 2の画像 2
    • Take the filter out and dispose of it.
  6. How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 6、 2の画像 1 How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 6、 2の画像 2
    • Remove the black part by gently pushing from inside of the canister.
  7. How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 7、 2の画像 1 How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 7、 2の画像 2
    • Clean both the canister and the black part either by rinsing it out or using a wash cloth.
  8. How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 8、 3の画像 1 How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 8、 3の画像 2 How to Replace a Nequare Cordless Vacuum S182 Filter: 手順 8、 3の画像 3
    • Put the black part back into the canister and put in the new filter.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Oghenefejiro Egede
メンバー登録日: 01/26/21
181 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G27, O'Regan Winter 2021 York University, Team S2-G27, O'Regan Winter 2021人のメンバー
YORK-O'REGAN-W21S2G27
2 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 45
今までの合計 1,273
