はじめに
For this guide, we outline the process of replacing a leaking set screw tub spout. Sometimes when a shower diverter becomes too old, it can’t block the water flow to divert the water to the showerhead. Replacing a leaky tub spout leads to an enormous amount of water and energy savings. Furthermore, a leaky tub spout can cause an expensive water bill as well. The heavier the leak, the more money you will have to end up paying.
必要な工具と部品
Cover the shower drain with a plug or a piece of cloth to prevent the screw from falling in.
Turn on the bath water to ensure the set screw tub spout has no leaks and is working as intended.
2 の人々がこのガイドを完成させました。
