メインコンテンツにスキップ
How to Replace a Kitchen Sink
必要な工具と部品
  1. How to Replace a Kitchen Sink, Kitchen Sink: 手順 1、 1の画像 1
    • Clear out the area for easy access. Place a disposable mat under the sink to make cleaning easier.
  2. How to Replace a Kitchen Sink: 手順 2、 2の画像 1 How to Replace a Kitchen Sink: 手順 2、 2の画像 2
    • Turn off the water supply prior to starting the repair process.
    • After turning off the water supply, turn on the water faucet for 30 seconds to relieve water pressure from the pipes.
  3. How to Replace a Kitchen Sink: 手順 3、 1の画像 1
    • Use an adjustable wrench to take apart the sink pipes.
    • There could be 3-5 pipes depending on the sink and other devices connected. As a rule of thumb, take apart every pipe that is connected but, make sure you know which pipe belongs where.
  4. How to Replace a Kitchen Sink: 手順 4、 1の画像 1
    • Remove the screw or clamp holding the sink to the countertop.
    • Screw shape varies depending on the sink so use the appropriate screwdriver.
  5. How to Replace a Kitchen Sink: 手順 5、 1の画像 1
    • Silicone caulk is used to hold the sink to the countertop and prevent water leakage or to prevent the sink from shifting. Remove the caulk by gently scrubbing the caulk off the edges using a utility knife.
    • After removing the caulk adhesive, you should be able to gently lift up the sink and remove it from its place.
    • Action is not demonstrated in the image.
  6. How to Replace a Kitchen Sink: 手順 6、 1の画像 1
    • After making sure the new sink fits, apply the silicone caulk between the sink and the countertop then gently place the sink back in place while applying a bit of pressure to activate the adhesive.
    • Let the caulk adhesive dry for 12 hours before using the sink again.
    • Time varies depending on silicone caulk.
    • Action not demonstrated in the image.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
M.hmza Daghstani
メンバー登録日: 01/22/21
160 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G7, Melo-Thaiss Winter 2021 York University, Team S1-G7, Melo-Thaiss Winter 2021人のメンバー
YORK-MELO-THAISS-W21S1G7
1 メンバー
1のガイドは作成済み
コメント 1 件
Thanks a lot.
kader287 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 27
今までの合計 1,324
