メインコンテンツにスキップ
How to Replace a Jeans Zipper with Buttons
必要な工具と部品
  1. How to Replace a Jeans Zipper with Buttons, Zipper: 手順 1、 3の画像 1 How to Replace a Jeans Zipper with Buttons, Zipper: 手順 1、 3の画像 2 How to Replace a Jeans Zipper with Buttons, Zipper: 手順 1、 3の画像 3
    • Open the broken zipper and identify the stitches.
    • Take the seam ripper and insert it under the last stitch seen.
    • Remove the stitches of the zipper and when most are removed, cut the rest of the zipper with fabric scissors.
    • Make sure to remove at least one half of the zipper.
  2. How to Replace a Jeans Zipper with Buttons: 手順 2、 2の画像 1 How to Replace a Jeans Zipper with Buttons: 手順 2、 2の画像 2
    • Insert the buttons tack to the right fly of the jeans.
    • Insert 2 or 3 button tacks, depending on the length of the fly.
    • Add textile glue to the pointed part of the tacks.
    • Adding glue to the tacks helps secure the buttons and avoids damage caused by the washing machine and daily use.
  3. How to Replace a Jeans Zipper with Buttons: 手順 3、 1の画像 1
    • While the textile glue is fresh, insert the buttons into the tacks and make sure they are secure.
    • You will notice the buttons are secure after you hear a clicking noise when pressing the buttons to the tacks.
  4. How to Replace a Jeans Zipper with Buttons: 手順 4、 1の画像 1
    • Cut three holes using the pointed part of the fabric scissor on the left fly of the jeans that correspond with the buttons on the right.
    • Make sure to open the fabric scissor and use only one blade.
    • Alternatively if you have access to a sewing machine, follow this guide to create the button holes.
  5. How to Replace a Jeans Zipper with Buttons: 手順 5、 1の画像 1
    • Using a needle and some thread, stitch the edges of the button holes to finish them.
  6. How to Replace a Jeans Zipper with Buttons: 手順 6、 1の画像 1
    • Make sure the buttons are secure, that they fit the holes, and that they open and close easily.
終わりに
At the end of the guide, you will have a pair of jeans that close with a set of buttons instead of a zipper.
作成者
1人の作成者と共同作成されました。
Luis Caraballo Ortiz
メンバー登録日: 03/18/22
133 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 103
今までの合計 3,521
