メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Replace a Hoodie Drawstring
必要な工具と部品
  1. How to Replace a Hoodie Drawstring, Hoodie Drawstring: 手順 1、 2の画像 1 How to Replace a Hoodie Drawstring, Hoodie Drawstring: 手順 1、 2の画像 2
    • If the broken or old drawstring is still in the hood, gently pull it through one of the hood holes.
  2. How to Replace a Hoodie Drawstring: 手順 2、 3の画像 1 How to Replace a Hoodie Drawstring: 手順 2、 3の画像 2 How to Replace a Hoodie Drawstring: 手順 2、 3の画像 3
    • Wrap a small piece of tape tightly around each end.
    • This step is if you have frayed edges on your drawstring.
  3. How to Replace a Hoodie Drawstring: 手順 3、 2の画像 1 How to Replace a Hoodie Drawstring: 手順 3、 2の画像 2
    • Open the safety pin and hook it through one end of the drawstring/shoelace.
    • If you put tape on frayed drawstring, stab the safety pin through the tape.
    • Be careful, your safety pin may be sharp!
    • Close the safety pin securely so it won't open when you put it in your hood.
  4. How to Replace a Hoodie Drawstring: 手順 4、 3の画像 1 How to Replace a Hoodie Drawstring: 手順 4、 3の画像 2 How to Replace a Hoodie Drawstring: 手順 4、 3の画像 3
    • Insert the safety-pinned end into one drawstring hole.
    • Work it through the hood by bunching and sliding the hoodie fabric along the pin.
    • Keep feeding the pin until it exits the opposite hole.
  5. How to Replace a Hoodie Drawstring: 手順 5、 2の画像 1 How to Replace a Hoodie Drawstring: 手順 5、 2の画像 2
    • Pull both ends of the drawstring until they're an even length.
    • Take out your safety pin.
    • Remove you tape (if any was used).
    • Make sure your string slides freely through the hood, and confirm it tightens as it's supposed to.
  6. How to Replace a Hoodie Drawstring: 手順 6、 3の画像 1 How to Replace a Hoodie Drawstring: 手順 6、 3の画像 2 How to Replace a Hoodie Drawstring: 手順 6、 3の画像 3
    • Tie a small knot on each end to keep the string from slipping back in your hood!
終わりに
Replacing a hoodie drawstring is a quick, simple repair that saves your favorite hoodie from the donation pile. You can use this same method for sweatpants, jackets, or gym bags.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Mia Johnson
メンバー登録日: 10/20/25
160 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 98-10, Kapoor Fall 2025 Austin Community College, Team 98-10, Kapoor Fall 2025人のメンバー
AUSTINCC-KAPOOR-F25S98G10
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 54
過去 30 日: 265
今までの合計 811
