メインコンテンツにスキップ
How to Replace a Cat5e Wall Jack
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. How to Replace a Cat5e Wall Jack, Cat5e Wall Jack: 手順 1、 1の画像 1
    • Remove the faceplate from the wall using either a phillips or flathead screwdriver.
  2. How to Replace a Cat5e Wall Jack: 手順 2、 1の画像 1
    • Once removed, un-clip the keystone jack from the wall plate by depressing the tab back side of the wall plate.
  3. How to Replace a Cat5e Wall Jack: 手順 3、 1の画像 1
    • Inspect the wiring and make note of the order of the wire locations.
  4. How to Replace a Cat5e Wall Jack: 手順 4、 1の画像 1
    • Remove the wires from the old jack by gently pulling them out of their connector slots.
  5. How to Replace a Cat5e Wall Jack: 手順 5、 1の画像 1
    • Trim the tips of the wires at the point where they were originally connected to help assure a good connection to the new jack.
  6. How to Replace a Cat5e Wall Jack: 手順 6、 1の画像 1
    • Separate the wires into the appropriate pairs and twist them together until about one half inch from the ends.
  7. How to Replace a Cat5e Wall Jack: 手順 7、 1の画像 1
    • Using the plastic punchdown tool, (typically supplied with a new jack), press the prepared wires into their appropriate locations on the replacement jack.
  8. How to Replace a Cat5e Wall Jack: 手順 8、 1の画像 1
    • Once all wires have been properly installed test the Ethernet connectivity with a known good Cat 5E cable and a working device, such as a laptop computer.
  9. How to Replace a Cat5e Wall Jack: 手順 9、 1の画像 1
    • After a good connection has been determined to exist, snap the new jack into the faceplate.
  10. How to Replace a Cat5e Wall Jack: 手順 10、 1の画像 1
    • Carefully insert the Cat5E wiring back into the wall and screw the face plate onto the wall.
  11. How to Replace a Cat5e Wall Jack: 手順 11、 1の画像 1
    • Hook up your Ethernet device and you are now ready to surf the web.
終わりに
If you're having trouble you can try the following troubleshooting steps: (1)Try using a different device in case your test device is having trouble, if the device is sound, (2) then try using a different Ethernet cable, finally, if the cable is good (3) make sure you didn't knock any wires out of place when you screwed the jack back in place. If everything works as it should, you have successfully replaced the Cat5e wall jack.
7 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
DelVonte Deary
メンバー登録日: 06/24/15
207 ポイント
1ガイドが承認済み
チーム
Colorado Springs, Team 1-5, Mcmichael SU 2015 Colorado Springs, Team 1-5, Mcmichael SU 2015人のメンバー
UCCS-MCMICHAEL-SU15S1G5
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,721
