メインコンテンツにスキップ
How to Replace a Broken Lamp Cord and Rotary Switch
必要な工具と部品
  1. How to Replace a Broken Lamp Cord and Rotary Switch, Lamp Cord with Rotary Switch: 手順 1、 1の画像 1
    • Unscrew the light bulb.
  2. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 2、 1の画像 1
    • Pinch the lamp shade hanger inwards.
    • Move one side of the lamp shade hanger out from under the clamp.
    • Take off the lamp shade hanger.
  3. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 3、 1の画像 1
    • Use the 1/4" flathead screwdriver to unscrew the socket screw to loosen the socket.
  4. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 4、 2の画像 1 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 4、 2の画像 2
    • Pull the socket away from the base.
  5. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 5、 1の画像 1
    • Cut the lamp wire with your wire trimmers.
  6. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 6、 2の画像 1 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 6、 2の画像 2
    • Pull apart the socket cap and shell.
    • Use vice grips if necessary for this step.
  7. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 7、 1の画像 1
    • Take the socket out of the socket shell.
    • Use a Phillips #2 screwdriver to partially unscrew the screws holding the copper wire to the socket so that you can disconnect the copper wire.
    • You may want to leave the screws partially unscrewed for when you reach Step 15.
    • Take the old wire out of the socket.
    • Discard old wire out of the reach of children and animals. Copper wire splinters can cause serious harm.
  8. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 8、 1の画像 1
    • Pull the other end of the broken cord out of the bottom of the lamp.
  9. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 9、 1の画像 1
    • Thread the new cord through the hole in the base of your lamp.
    • If you have trouble threading the wire, and your wire has a split end, consider using electrical tape to cover the end.
  10. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 10、 1の画像 1
    • Thread the cord through the whole body of your lamp.
    • If you're still having trouble threading your lamp, you may want to disassemble your lamp body and thread the cord through each piece individually like this step's picture shows.
  11. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 11、 2の画像 1 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 11、 2の画像 2
    • Thread the cord through the lamp shade hanger clamp.
    • Attach the lamp shade hanger clamp back onto the lamp body.
    • Thread the cord through the socket cap.
    • Attach the socket cap back onto the lamp body.
    • Screw the socket screw back into the socket cap with the 1/4" flathead screwdriver.
  12. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 12、 1の画像 1
    • Split the end of the cord by about 2 to 3 inches.
  13. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 13、 3の画像 1 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 13、 3の画像 2 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 13、 3の画像 3
    • Tie an Underwriter's Loop with the following steps:
    • Loop the left side of the cord around and hold it behind the right side.
    • Loop the right side of the cord around the end of the left side.
    • Thread the end of the right side through the left loop.
    • Gently pull on both ends of the cord to tighten the knot.
    • Do not tighten the knot all the way. A good underwriter's knot will have some flexibility and bounce. The purpose of this loop is to prevent strain on the cord whenever it is pulled so that the copper wires are not broken or pulled out of place.
  14. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 14、 3の画像 1 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 14、 3の画像 2 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 14、 3の画像 3
    • Using your wire trimmers or multi-tool, strip away the cord casing on each side to expose the ends of the copper wire.
    • Gently twist the exposed copper wire on each side.
    • Bend the copper wire to create a hook shape.
  15. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 15、 3の画像 1 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 15、 3の画像 2 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 15、 3の画像 3
    • Hook the smooth side of your cord over the brass screw.
    • Gently tighten the screw with the Phillips #2 screwdriver until you can't pull the copper wire out.
    • Hook the ribbed side of your cord over the silver screw and tighten the screw with the Phillips #2 screwdriver.
    • Make sure you hook the correct end of your cord over the correct screw. Reversing your ends could result in electrocution or fire. Triple check your cord for the ribbed side (which will feel like it has little ridges) and the smooth side (which will be smooth).
    • Once you have tightened the screws, loosen the underwriter's knot slightly, so that there is plenty of slack in the knot.
  16. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 16、 2の画像 1 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 16、 2の画像 2
    • Place the socket shell back onto the socket.
    • Push the socket shell and cap back together.
    • At this point, you are done working with the body of the lamp until step 24.
  17. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 17、 1の画像 1
    • From this point forward, until Step 24, you will work with the cord tail that comes from the bottom of your lamp.
    • Mark where you want your toggle switch to go.
    • Using the wire trimmers, cut the cord on the mark.
  18. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 18、 1の画像 1
    • Pull the ends of the cord apart.
    • You may need to cut between the sides of the cord to be able to pull it apart.
    • This step repeats the skills used in Step 14.
    • Using your wire trimmers or multi-tool, strip the cord casing away from the copper wire on both sides of the cord.
    • Gently twist both ends of the copper wire.
  19. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 19、 2の画像 1 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 19、 2の画像 2
    • Unscrew the two screws on the back of the toggle switch with the Phillips #2 screwdriver to open up the switch.
  20. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 20、 1の画像 1
    • Unscrew the two screws on the wire clip with the Phillips #2 screwdriver.
  21. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 21、 2の画像 1 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 21、 2の画像 2
    • Loosen, but don't remove, the four screws on the copper plates with the Phillips #2 screwdriver.
    • In the following step, with the toggle switch used in this guide, the ribbed side of the cord attaches to the terminal marked "N." The smooth side of the cord attaches to the terminal marked "L."
    • To place the wire, follow these steps:
    • Thread one end of the copper wire through the hole underneath one screw.
    • Tighten the screw with the Phillips #2 screwdriver so that it clamps the copper wire to the copper plate.
    • Repeat the above steps for each end of the cord.
  22. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 22、 2の画像 1 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 22、 2の画像 2
    • Hold a wire clip over one end of your cord.
    • Screw the clip back onto the switch with the Phillips #2 screwdriver.
    • Repeat for the other side.
  23. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 23、 2の画像 1 How to Replace a Broken Lamp Cord and Rotary Switch: 手順 23、 2の画像 2
    • Screw the bottom of the switch back on with the Phillips #2 screwdriver.
  24. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 24、 1の画像 1
    • From this step until the end of the guide, you will be working with the main lamp body again.
    • Replace the lamp shade hanger into the clamp.
  25. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 25、 1の画像 1
    • Screw the light bulb back into the socket.
  26. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 26、 1の画像 1
    • Replace the lamp shade.
  27. How to Replace a Broken Lamp Cord and Rotary Switch: 手順 27、 1の画像 1
    • Plug in your lamp to check that you did the wiring correctly.
    • Use caution when you test your lamp. Be sure to do this in a controlled environment with no children or animals present in case your wiring is incorrect.
終わりに
You should now have a fixed, functional lamp with a new cord and toggle switch.
作成者
1人の作成者と共同作成されました。
Rebecca Johnson
メンバー登録日: 02/19/21
385 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-12, Martin Fall 2023 University of North Texas, Team 1-12, Martin Fall 2023人のメンバー
UNT-MARTIN-F23S1G12
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 92
今までの合計 524
