メインコンテンツにスキップ
How to Replace a Broken Blind Slat
必要な工具と部品
  1. How to Replace a Broken Blind Slat, Horizontal Blind Slat: 手順 1、 1の画像 1
    • Using the 7/32" flathead screwdriver, gently lift up the buttons located on the bottom rail of the blinds.
    • Make sure to be careful when lifting the bottom buttons to avoid injury and button damage.
  2. How to Replace a Broken Blind Slat: 手順 2、 2の画像 1 How to Replace a Broken Blind Slat: 手順 2、 2の画像 2
    • Remove the bottom rail buttons to expose knots at the end of the lifting cords.
    • Untie the knots.
  3. How to Replace a Broken Blind Slat: 手順 3、 1の画像 1
    • Start at the highest damaged slat.
    • Begin pulling the lifting cords up through the route holes of all the following blind slats.
    • If you don't start from the highest slat, it will result in you doing way more work than you have to.
  4. How to Replace a Broken Blind Slat: 手順 4、 2の画像 1 How to Replace a Broken Blind Slat: 手順 4、 2の画像 2
    • Again, start with the highest slat.
    • Begin removing the broken slat(s) from in between the ladder strings.
  5. How to Replace a Broken Blind Slat: 手順 5、 1の画像 1
    • Slide in the replacement slat(s).
    • Be sure the slat(s) sits in place upon the rungs of the ladder strings.
  6. How to Replace a Broken Blind Slat: 手順 6、 1の画像 1
    • With the new replacement slats in place, begin at the highest slat.
    • Create a loop with the lifting cords.
    • Slide the loop through each routing hole on the same side of all the slats.
    • Repeat this step on the other side, and in the middle if your blinds have three routing holes.
  7. How to Replace a Broken Blind Slat: 手順 7、 3の画像 1 How to Replace a Broken Blind Slat: 手順 7、 3の画像 2 How to Replace a Broken Blind Slat: 手順 7、 3の画像 3
    • Once you reach the bottom slat, thread the lifting cords back through the bottom rail.
    • Make sure the lifting cords are even in length and the bottom rail is aligned straight horizontally.
  8. How to Replace a Broken Blind Slat: 手順 8、 3の画像 1 How to Replace a Broken Blind Slat: 手順 8、 3の画像 2 How to Replace a Broken Blind Slat: 手順 8、 3の画像 3
    • Use the 7/32" flathead screwdriver to push the excess lifting cords into the bottom rail holes.
    • Slide the buttons back over the ends of the cords.
    • At each bottom rail button, double knot the lifting cords.
  9. How to Replace a Broken Blind Slat: 手順 9、 1の画像 1
    • Plug the buttons back into the bottom rail.
  10. How to Replace a Broken Blind Slat: 手順 10、 2の画像 1 How to Replace a Broken Blind Slat: 手順 10、 2の画像 2
    • Lastly, gently hammer the bottom rail buttons with the handle of the 7/32" flathead screwdriver to ensure the button is securely fastened.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Jazmine Atkins
メンバー登録日: 01/25/20
265 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020人のメンバー
USFSM-STEWART-S20S1G1
23 メンバー
28のガイドは作成済み
2 件のコメント
Very good tutorial. Thank you.
LaReisa Cares - 返信
What happened when that string retracts and goes missing ?
Mary Nguyen - 返信
コメントを追加
統計データ:
過去 24時間: 15
過去 7 日: 71
過去 30 日: 403
今までの合計 15,898
