メインコンテンツにスキップ
How to Replace a Bottom Bracket on a Bicycle
必要な工具と部品
  1. How to Replace a Bottom Bracket on a Bicycle, Bottom Bracket: 手順 1、 1の画像 1
    • Flip the bike so that it is resting on the handle bars and seat.
  2. How to Replace a Bottom Bracket on a Bicycle: 手順 2、 3の画像 1 How to Replace a Bottom Bracket on a Bicycle: 手順 2、 3の画像 2 How to Replace a Bottom Bracket on a Bicycle: 手順 2、 3の画像 3
    • Take out the bolts on the base of the crank using an allen wrench that fits the bolt.
    • Do this to both sides. Set the bolts aside.
  3. How to Replace a Bottom Bracket on a Bicycle: 手順 3、 3の画像 1 How to Replace a Bottom Bracket on a Bicycle: 手順 3、 3の画像 2 How to Replace a Bottom Bracket on a Bicycle: 手順 3、 3の画像 3
    • Screw the crank puller into the place where the bolts used to be.
    • Tighten the crank puller until it pulls the crank off the bike.
    • Repeat for the other side.
    • Set aside the cranks, keeping track of which side each one goes on.
  4. How to Replace a Bottom Bracket on a Bicycle: 手順 4、 2の画像 1 How to Replace a Bottom Bracket on a Bicycle: 手順 4、 2の画像 2
    • Go to the side that does not have the drive train. This side must be completed first!
    • Insert the bottom bracket tool into the bottom bracket. Use the tool to turn the bottom bracket counter clock wise. It will be difficult to turn, but enough force will get it to turn.
    • Completely remove the small side of the bottom bracket.
    • Repeat for the side with the drive train, except turn the bottom bracket tool clockwise this time.
  5. How to Replace a Bottom Bracket on a Bicycle: 手順 5、 1の画像 1
    • Pull out the damaged bottom bracket from the drive train side.
    • Discard the broken bottom bracket.
  6. How to Replace a Bottom Bracket on a Bicycle: 手順 6、 2の画像 1 How to Replace a Bottom Bracket on a Bicycle: 手順 6、 2の画像 2
    • Get the new bottom bracket.
    • Notice the left (L) and right (R) markers on the part. This will help guide you when inserting the part.
    • Grease both parts of the threads using the paint brush. Apply enough grease so that the threads are evenly coated.
  7. How to Replace a Bottom Bracket on a Bicycle: 手順 7、 3の画像 1 How to Replace a Bottom Bracket on a Bicycle: 手順 7、 3の画像 2 How to Replace a Bottom Bracket on a Bicycle: 手順 7、 3の画像 3
    • Insert the bottom bracket from the drive side of the bike with the larger side facing your hand.
    • Gently screw in the second set of threads on the other side with your fingers.
  8. How to Replace a Bottom Bracket on a Bicycle: 手順 8、 2の画像 1 How to Replace a Bottom Bracket on a Bicycle: 手順 8、 2の画像 2
    • Use the bottom bracket tool to screw in the larger side (drive side) of the bottom bracket. Make sure to screw it in counter clock wise.
    • Screw the bottom bracket in all the way, but make sure not to tighten it down.
    • Repeat for the smaller side, except screw the bottom bracket in clock wise.
    • Tighten both sides down with the bottom bracket tool.
  9. How to Replace a Bottom Bracket on a Bicycle: 手順 9、 2の画像 1 How to Replace a Bottom Bracket on a Bicycle: 手順 9、 2の画像 2
    • Put the cranks back on their corresponding sides.
    • Make sure the chain goes back around the chain ring.
    • Put the bolts back through and tighten them into place with the allen wrench used earlier.
  10. How to Replace a Bottom Bracket on a Bicycle: 手順 10、 1の画像 1
    • Rotate the pedals with your hands to check that the bottom bracket is rotating smoothly and not catching.
終わりに
Congratulations! You are finished and can ride your bike again!
12 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Kaitlin Brenneman
メンバー登録日: 09/29/15
601 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-6, Green Fall 2015 Cal Poly, Team 10-6, Green Fall 2015人のメンバー
CPSU-GREEN-F15S10G6
3 メンバー
3のガイドは作成済み
コメント 1 件
Some people just like the feel of holding the catalog, newspaper Free Catalog or magazine in their hands.
seo - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 111
今までの合計 24,289
