メインコンテンツにスキップ
How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22
必要な工具と部品
  1. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22, Windsshiled Wiper blades.: 手順 1、 2の画像 1 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22, Windsshiled Wiper blades.: 手順 1、 2の画像 2
    • Put the wipers in service position. To do that you must get into the vehicle.
    • Then push the ignition button ON and OFF.
    • Push the wiper stock down once which will lift your wiper arms.
  2. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: 手順 2、 3の画像 1 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: 手順 2、 3の画像 2 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: 手順 2、 3の画像 3
    • After you are done with your first step your wiper blades position should be up as shown in the image.
    • Once they are in the service position lift the wiper blades to about 120 degree.
  3. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: 手順 3、 1の画像 1
    • Place a towel or piece of rough cloth on the windshield.
    • Placing towel on windscreen helps protect windshield from the metal wiper arms as they are spring-loaded.
  4. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: 手順 4、 3の画像 1 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: 手順 4、 3の画像 2 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: 手順 4、 3の画像 3
    • Remove the old wiper blade by pressing the little square button on the wiper mounting arm.
    • Keep pressing the button while lifting the wiper blade in the direction of the wiper arm and pull the wiper blade away from the arm.
    • Remember this step might require a bit of pressure.
  5. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: 手順 5、 1の画像 1
    • After the blade is removed gently place back the wiper arms on the windscreen.
  6. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: 手順 6、 3の画像 1 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: 手順 6、 3の画像 2 How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: 手順 6、 3の画像 3
    • Now take the new wiper blade and sliding directly into the wiper arm mount. You will hear a click once the new blade has been mounted properly.
    • Make sure the new wiper blades latches perfectly with the mount.
  7. How to Replace Windshield Wiper Blades for Volkswagen Jetta 2019-22: 手順 7、 1の画像 1
    • Remove the cloth from the windshield and place your wipers gently onto the windscreen.
終わりに
You can follow the same steps for the other wiper arm. Also make sure to check the wipers before hitting the road.
作成者
1人の作成者と共同作成されました。
Yashkumar Patel
メンバー登録日: 01/17/23
145 ポイント
1ガイドが承認済み
チーム
York University, Team O-28, Woodhouse Winter 2023 York University, Team O-28, Woodhouse Winter 2023人のメンバー
YORK-WOODHOUSE-W23SOG28
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 80
今までの合計 970
