メインコンテンツにスキップ
How to Replace Underside Fabric of a Chair
必要な工具と部品
  1. How to Replace Underside Fabric of a Chair, Underside Fabric: 手順 1、 1の画像 1
    • Turn the armchair on its back.
  2. How to Replace Underside Fabric of a Chair: 手順 2、 1の画像 1
    • Use pliers to remove the staples from the chair frame.
    • If the staples are too difficult to remove, cut away the fabric with scissors.
  3. How to Replace Underside Fabric of a Chair: 手順 3、 1の画像 1
    • Measure out the dimensions of the perimeter of the chair frame.
    • Add an extra inch to each side to allow for error.
  4. How to Replace Underside Fabric of a Chair: 手順 4、 2の画像 1 How to Replace Underside Fabric of a Chair: 手順 4、 2の画像 2
    • Trace the dimensions onto the new fabric.
    • Cut along the traced lines.
  5. How to Replace Underside Fabric of a Chair: 手順 5、 1の画像 1
    • Fold under approximately a 1-inch allowance from the fabric’s edges.
    • Adjust the folded edges as needed to the correct size.
  6. How to Replace Underside Fabric of a Chair: 手順 6、 2の画像 1 How to Replace Underside Fabric of a Chair: 手順 6、 2の画像 2
    • Use a staple gun to staple the fabric to the chair frame starting at one corner.
    • If the staples do not go all the way into the chair frame, tap lightly with a hammer.
  7. How to Replace Underside Fabric of a Chair: 手順 7、 1の画像 1
    • Sit the chair upright and make sure the fabric is not visible or sagging.
    • If the fabric is visible, remove the staples from the closest corner and pull taut.
ゴール
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Nicole Keller
メンバー登録日: 06/09/16
294 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team 3-3, Rauch SU 2016 Texas Tech, Team 3-3, Rauch SU 2016人のメンバー
TTU-RAUCH-SU16S3G3
2 メンバー
1のガイドは作成済み
2 件のコメント
excellent ways to repair the home furniture. thanks for your ways of writing such a good article about furniture.
Nice post written by Nicole Keller.
http://www.birchi.in/kids-and-baby/kids-...
Birchi In - 返信
Thanks a lot! Wish I knew this a couple of weeks ago. Instead, I went and bought two all new 1 seater sofas in Sydney,
Lucas Bergman - 返信
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 52
過去 30 日: 234
今までの合計 22,204
