メインコンテンツにスキップ
How to Replace Sony MDR-7506 Ear Pads
必要な工具と部品
  1. How to Replace Sony MDR-7506 Ear Pads, Ear Pads: 手順 1、 1の画像 1
    • CAUTION: For safe-handling (preventing damage or dislocation of the wires or other components) rotate the earcups to their inverse position about ~ 180° degrees from resting position.
  2. How to Replace Sony MDR-7506 Ear Pads: 手順 2、 3の画像 1 How to Replace Sony MDR-7506 Ear Pads: 手順 2、 3の画像 2 How to Replace Sony MDR-7506 Ear Pads: 手順 2、 3の画像 3
    • Carefully peel the cushions off, closer to the seams, along the speaker's outer edge.
    • Fully remove the ear pads without any yanking or excessive jerking motions.
    • Repeat for the other side's ear pad.
  3. How to Replace Sony MDR-7506 Ear Pads: 手順 3、 1の画像 1
    • These replacement ear cushions appear to be high-quality, come with a warranty, and a set of instructions (as shown in the first image).
    • Also, "hear" is a quick comparison between the tattered/old ear cushions (left) and the new ear cushions (right).
  4. How to Replace Sony MDR-7506 Ear Pads: 手順 4、 2の画像 1 How to Replace Sony MDR-7506 Ear Pads: 手順 4、 2の画像 2
    • Place the new headphone cushions flush to each of the speakers' edges (padded-side facing outward from speaker).
    • Align with proper orientation of side-lengths.
    • The first image in this step is misaligned and can lead to tearing or inconvenience, once fixating begins.
  5. How to Replace Sony MDR-7506 Ear Pads: 手順 5、 3の画像 1 How to Replace Sony MDR-7506 Ear Pads: 手順 5、 3の画像 2 How to Replace Sony MDR-7506 Ear Pads: 手順 5、 3の画像 3
    • Begin wrapping the ear cushions by securing the leather around the edges of each speaker. Insert the non-cushion side flaps into the allotted crevice.
    • Work around the edges of each speaker until complete.
    • Initial stretching for proper fitment may be required; however, carefully hold down the wrapped parts in place while pulling the free lip over the speaker edges - as shown in the second image.
  6. How to Replace Sony MDR-7506 Ear Pads: 手順 6、 2の画像 1 How to Replace Sony MDR-7506 Ear Pads: 手順 6、 2の画像 2
    • Finally, check around the ear pads to ensure they are completely wrapped and secure.
    • For any mistakes, misalignments, or loose ends, this process may be repeated or small corrections can be made (avoid tearing by removing ear pads completely for large adjustments).
終わりに
Enjoy your refreshed ear pads!
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Zachary Taha
メンバー登録日: 08/24/22
181 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 3-22, Briggs Fall 2022 CSU Los Angeles, Team 3-22, Briggs Fall 2022人のメンバー
CSULA-BRIGGS-F22S3G22
1 メンバー
1のガイドは作成済み
コメント 1 件
ON SONY DR-S100 units i accidently destroyed an oval shaped piece of paper like material that covered the many holes around the speaker element. What kind of material is it?
Bill G - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 17
過去 30 日: 80
今までの合計 2,783
