メインコンテンツにスキップ
How to Replace Scott Mountain Bike Handlebars
必要な工具と部品
  1. How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: 手順 1、 2の画像 1 How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: 手順 1、 2の画像 2
    • Prop bike upright
    • Unscrew the hex bolts holding the front and rear shifter in place.
    • Use the H4 size hex wrench
    • Repeat for other side of handlebars.
  2. How to Replace Scott Mountain Bike Handlebars: 手順 2、 1の画像 1
    • Slide the shifters toward the center of the handlebars so there is a gap between them and the grips.
  3. How to Replace Scott Mountain Bike Handlebars: 手順 3、 1の画像 1
    • Use a flathead screwdriver to wedge a gap between the grip and the handlebars.
    • Twist grip around until it comes off of handlebar.
  4. How to Replace Scott Mountain Bike Handlebars: 手順 4、 1の画像 1
    • Slide the shifters off of the end of the handlebars.
    • Let them hang on the bike.
  5. How to Replace Scott Mountain Bike Handlebars: 手順 5、 1の画像 1
    • Unscrew the hex bolts holding the center bracket in place.
    • Use H3 hex wrench.
    • Place center bracket and hex screws off to the side. They will be needed in the next step.
  6. How to Replace Scott Mountain Bike Handlebars: 手順 6、 1の画像 1
    • Attach new handlebars and screw the center bracket back in place.
    • Make sure that handlebars are centered.
  7. How to Replace Scott Mountain Bike Handlebars: 手順 7、 1の画像 1
    • Slide the shifters back onto the handlebars so that the numbers are upright.
    • Do not screw them back in place yet.
  8. How to Replace Scott Mountain Bike Handlebars: 手順 8、 1の画像 1
    • Slide the handlebar grips back onto the ends of the handlebars.
    • Slide the shifters back against the grips and screw them into place.
終わりに
By following these steps, you will have your bike ready in no time.
作成者
4人の作成者と共同で作成されました。
Sean Slater
メンバー登録日: 02/24/15
139 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 23-3, Green Winter 2015 Cal Poly, Team 23-3, Green Winter 2015人のメンバー
CPSU-GREEN-W15S23G3
6 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 20
今までの合計 1,736
