メインコンテンツにスキップ
How to Replace Hot and Cold Water Pipes for a Washer
必要な工具と部品
  1. How to Replace Hot and Cold Water Pipes for a Washer, How to Replace Hot and Cold Water Pipes for a Washer: 手順 1、 1の画像 1
    • Before starting this guide, shut off your water to the washer and dryer. In this guide, valves are used. Some newer setups may use levers.
    • Mark the hot and cold water pipelines with a marker for proper visuals.
    • Hot water
    • Cold water
  2. How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: 手順 2、 3の画像 1 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: 手順 2、 3の画像 2 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: 手順 2、 3の画像 3
    • Using an adjustable wrench, disconnect the pipes carefully from the water supply side and the washer side.
    • After the pipes are disconnected, re-check the leakage and rust in the washer installation.
  3. How to Replace Hot and Cold Water Pipes for a Washer: 手順 3、 1の画像 1
    • Rotate the adjustable wrench in a counter-clockwise direction to loosen the pipe connection.
    • Make sure to remove the old white Teflon tape. Use a bucket and a piece of cloth for water damps from the connection.
  4. How to Replace Hot and Cold Water Pipes for a Washer, Prepare the new pipes: 手順 4、 1の画像 1
    • Set up the new pipes to be installed.
    • Check for blockage or any cracks in the valve.
  5. How to Replace Hot and Cold Water Pipes for a Washer, Wrap new Teflon tape: 手順 5、 1の画像 1
    • Wrap the new piece of Teflon tape around the shut-off valve connection.
  6. How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: 手順 6、 3の画像 1 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: 手順 6、 3の画像 2 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: 手順 6、 3の画像 3
    • Install and connect the new pipes using an adjustable wrench.
  7. How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: 手順 7、 2の画像 1 How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: 手順 7、 2の画像 2
    • Rotate the pipes in a clockwise direction to tighten up.
    • Turn on the water supply. Perform a quick wash and check the connection.
終わりに
  • This guide contains easy steps of instructions to be followed if your pipes of the washer are needed to be changed.
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Jenish
メンバー登録日: 01/22/21
169 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G21, Melo-Thaiss Winter 2021 York University, Team S1-G21, Melo-Thaiss Winter 2021人のメンバー
YORK-MELO-THAISS-W21S1G21
1 メンバー
1のガイドは作成済み
コメント 1 件
Those are hoses. Pipes are in the wall
NitWit - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 30
過去 30 日: 186
今までの合計 7,923
