メインコンテンツにスキップ
How to Replace Concealed Cabinet Hinges
必要な工具と部品
  1. How to Replace Concealed Cabinet Hinges, Hinge: 手順 1、 3の画像 1 How to Replace Concealed Cabinet Hinges, Hinge: 手順 1、 3の画像 2 How to Replace Concealed Cabinet Hinges, Hinge: 手順 1、 3の画像 3
    • Remove the screws that are attached to the cabinet door.
    • Unscrew the top and bottom hinges even if you are only replacing one hinge.
    • Remove the cabinet door from the hinge.
    • You may need to wiggle or pry the door off.
  2. How to Replace Concealed Cabinet Hinges: 手順 2、 2の画像 1 How to Replace Concealed Cabinet Hinges: 手順 2、 2の画像 2
    • Remove the screws that go into the cabinet frame from the hinge, then remove the hinge.
    • Only the hinge being replaced needs to be removed.
  3. How to Replace Concealed Cabinet Hinges: 手順 3、 3の画像 1 How to Replace Concealed Cabinet Hinges: 手順 3、 3の画像 2 How to Replace Concealed Cabinet Hinges: 手順 3、 3の画像 3
    • Insert the new hinge into the cabinet door's pre-cut hole.
    • Attach the hinge with the provided screws.
    • To avoid striping the screws, do not over tighten.
  4. How to Replace Concealed Cabinet Hinges: 手順 4、 1の画像 1
    • Reattach the cabinet door to the cabinet frame.
    • Do not tighten the screws all the way. You will need to align the door later.
    • You may need a friend to hold the door while you screw it back into place.
  5. How to Replace Concealed Cabinet Hinges: 手順 5、 2の画像 1 How to Replace Concealed Cabinet Hinges: 手順 5、 2の画像 2
    • Lift or lower the cabinet door to align the hinges with its original location.
    • Changes in wood stain can serve as a useful alignment guide.
    • Tighten all the screws.
  6. How to Replace Concealed Cabinet Hinges: 手順 6、 3の画像 1 How to Replace Concealed Cabinet Hinges: 手順 6、 3の画像 2 How to Replace Concealed Cabinet Hinges: 手順 6、 3の画像 3
    • Use this step to adjust the amount of space between the cabinet door and the cabinet frame.
    • Loosen the adjustment screws, but do not remove them.
    • Slide the cabinet door to your desired position.
    • Tighten the screws.
  7. How to Replace Concealed Cabinet Hinges: 手順 7、 1の画像 1
    • Use this step if your cabinet door closes too hard or does not completely close.
    • Tighten this screw to keep the cabinet door from closing too hard. Loosen the screw to allow the cabinet door to close completely.
    • Do not completely remove this screw.
ゴール
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Naomi Frazier
メンバー登録日: 04/28/17
171 ポイント
1ガイドが承認済み
チーム
UC Davis, Team S4-G4, Cole Spring 2017 UC Davis, Team S4-G4, Cole Spring 2017人のメンバー
UCD-COLE-S17S4G4
3 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 24
過去 30 日: 142
今までの合計 29,802
