メインコンテンツにスキップ
How to Replace Cabinet Door Bumpers
必要な工具と部品
  1. How to Replace Cabinet Door Bumpers, Cabinet Door Bumpers: 手順 1、 3の画像 1 How to Replace Cabinet Door Bumpers, Cabinet Door Bumpers: 手順 1、 3の画像 2 How to Replace Cabinet Door Bumpers, Cabinet Door Bumpers: 手順 1、 3の画像 3
    • Open the cabinet door to access the existing bumpers.
  2. How to Replace Cabinet Door Bumpers: 手順 2、 3の画像 1 How to Replace Cabinet Door Bumpers: 手順 2、 3の画像 2 How to Replace Cabinet Door Bumpers: 手順 2、 3の画像 3
    • Use a plastic scraper to remove the existing bumpers.
    • Using a metal scraper or excessive force could scratch your cabinets.
  3. How to Replace Cabinet Door Bumpers: 手順 3、 3の画像 1 How to Replace Cabinet Door Bumpers: 手順 3、 3の画像 2 How to Replace Cabinet Door Bumpers: 手順 3、 3の画像 3
    • Apply a small amount of adhesive remover to a paper towel.
    • Rub the area where the old bumpers were located to remove any sticky residue.
    • Use WD-40 or rubbing alcohol to remove sticky residue from stainless steel cabinets.
  4. How to Replace Cabinet Door Bumpers: 手順 4、 3の画像 1 How to Replace Cabinet Door Bumpers: 手順 4、 3の画像 2 How to Replace Cabinet Door Bumpers: 手順 4、 3の画像 3
    • Clean the area with a damp cloth and mild soap to remove any remaining adhesive remover or residue.
  5. How to Replace Cabinet Door Bumpers: 手順 5、 1の画像 1
    • Let the area dry completely.
  6. How to Replace Cabinet Door Bumpers: 手順 6、 3の画像 1 How to Replace Cabinet Door Bumpers: 手順 6、 3の画像 2 How to Replace Cabinet Door Bumpers: 手順 6、 3の画像 3
    • Peel off the backing from the adhesive side of the new bumpers.
    • Place the new bumper onto the clean, dry surface where the old bumpers used to be.
    • Press the bumper onto the cabinet to secure the adhesive.
  7. How to Replace Cabinet Door Bumpers: 手順 7、 3の画像 1 How to Replace Cabinet Door Bumpers: 手順 7、 3の画像 2 How to Replace Cabinet Door Bumpers: 手順 7、 3の画像 3
    • Open and close the cabinet doors a few times to ensure that the new bumpers are securely in place and effectively cushioning the doors.
ゴール
作成者
3人の作成者と共同で作成されました。
Brenda M
メンバー登録日: 06/23/24
145 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 6-11, Watkins Summer 2024 Austin Community College, Team 6-11, Watkins Summer 2024人のメンバー
AUSTINCC-WATKINS-SU24S6G11
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 52
今までの合計 765
