メインコンテンツにスキップ
How to Repair the Lining of a Leather Wallet
必要な工具と部品
  1. How to Repair the Lining of a Leather Wallet, Lining: 手順 1、 1の画像 1
    • Use scissors to cut any hanging threads.
  2. How to Repair the Lining of a Leather Wallet: 手順 2、 2の画像 1 How to Repair the Lining of a Leather Wallet: 手順 2、 2の画像 2
    • Flip the entire wallet inside out.
  3. How to Repair the Lining of a Leather Wallet: 手順 3、 3の画像 1 How to Repair the Lining of a Leather Wallet: 手順 3、 3の画像 2 How to Repair the Lining of a Leather Wallet: 手順 3、 3の画像 3
    • Pin the cloth into place with safety pins.
    • Make sure not to poke through the leather. If there is no way to do this without damaging the leather, skip this step.
  4. How to Repair the Lining of a Leather Wallet: 手順 4、 2の画像 1 How to Repair the Lining of a Leather Wallet: 手順 4、 2の画像 2
    • Cut about a centimeter off the end of the sewing thread to get rid of any fraying.
    • Guide the thread through the hole at the top of the needle.
    • Pull about 20.32-30.48 cm of the thread through to prevent the thread from slipping out while sewing.
    • If it is too difficult to get the thread through the hole, wet the end of the thread and roll it between two fingers to create a pointed end and try again.
    • Cut about 0.91 meters of thread from the spool.
  5. How to Repair the Lining of a Leather Wallet: 手順 5、 3の画像 1 How to Repair the Lining of a Leather Wallet: 手順 5、 3の画像 2 How to Repair the Lining of a Leather Wallet: 手順 5、 3の画像 3
    • Starting at the beginning of the tear, sew thread from the inside of the wallet to the outside.
    • Sew thread back from the outside of the wallet to the inside of the wallet.
    • Tie the threads together 2 or 3 times.
    • Leave very little gap between first and second stitch hole.
  6. How to Repair the Lining of a Leather Wallet: 手順 6、 2の画像 1 How to Repair the Lining of a Leather Wallet: 手順 6、 2の画像 2
    • Locate holes in the leather from existing stitches and sew through them, making sure to avoid damaging it.
    • Perform a standard backstitch: skip one of the holes and sew from the inside of the wallet to the outside through second hole, then sew from the outside to the inside through the hole that was skipped.
    • Repeat until the lining is completely reattached.
  7. How to Repair the Lining of a Leather Wallet: 手順 7、 2の画像 1 How to Repair the Lining of a Leather Wallet: 手順 7、 2の画像 2
    • At the end of the tear, sew from the inside of the wallet to the outside, leaving a sizable loop of thread.
    • Sew thread back from the outside of the wallet to the inside, leaving very little space between stitches.
  8. How to Repair the Lining of a Leather Wallet: 手順 8、 2の画像 1 How to Repair the Lining of a Leather Wallet: 手順 8、 2の画像 2
    • Tie the loop and the hanging thread together 2 or 3 times.
  9. How to Repair the Lining of a Leather Wallet: 手順 9、 2の画像 1 How to Repair the Lining of a Leather Wallet: 手順 9、 2の画像 2
    • Cut any extra thread and remove the safety pins.
  10. How to Repair the Lining of a Leather Wallet: 手順 10、 2の画像 1 How to Repair the Lining of a Leather Wallet: 手順 10、 2の画像 2
    • Flip the wallet back so the lining is on the inside.
    • The lining should be securely attached to the interior of the wallet!
ゴール
作成者
2人の作成者と共同で作成されました。
Riya
メンバー登録日: 01/26/23
181 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 2-6, Morris Winter 2023 UC Davis, Team 2-6, Morris Winter 2023人のメンバー
UCD-MORRIS-W23S2G6
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 21
過去 30 日: 94
今までの合計 956
