メインコンテンツにスキップ
How to Repair the Broken Toe Strap of a Fabric Sandal
必要な工具と部品
  1. How to Repair the Broken Toe Strap of a Fabric Sandal, How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 1、 2の画像 1 How to Repair the Broken Toe Strap of a Fabric Sandal, How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 1、 2の画像 2
    • Draw a rectangle on the bottom of the sandal that centers the hole of the toe strap.
  2. How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 2、 3の画像 1 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 2、 3の画像 2 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 2、 3の画像 3
    • Slice through three connecting sides at the bottom of the rectangle using a box cutter.
    • Keep your fingers away from the box cutter to avoid injury.
    • Create shallow slices to avoid cutting through the sandal.
  3. How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 3、 3の画像 1 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 3、 3の画像 2 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 3、 3の画像 3
    • Insert a toothpick into the bottom slit.
    • Use the toothpick as a lever to wedge open the flap.
    • Use an extra toothpick if the first one breaks.
  4. How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 4、 3の画像 1 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 4、 3の画像 2 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 4、 3の画像 3
    • Slide the toe strap through the hole of the sandal until you feel resistance.
  5. How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 5、 3の画像 1 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 5、 3の画像 2 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 5、 3の画像 3
    • Flatten the toe strap against the insole of the sandal.
  6. How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 6、 3の画像 1 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 6、 3の画像 2 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 6、 3の画像 3
    • Apply the glue to the toe strap and inside the flap of the sandal.
    • Wear protective gloves to avoid skin irritation.
  7. How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 7、 3の画像 1 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 7、 3の画像 2 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 7、 3の画像 3
    • Close the sole flap.
    • Press the flap down until it is even with the sole of the sandal.
  8. How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 8、 2の画像 1 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 8、 2の画像 2
    • Use the trigger clamp to tightly press the flap against the sandal.
  9. How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 9、 3の画像 1 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 9、 3の画像 2 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 9、 3の画像 3
    • Tighten the trigger clamp by squeezing the trigger.
    • Leave the trigger clamp on the sandal to dry overnight.
  10. How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 10、 1の画像 1
    • Remove the trigger clamp by pressing the quick-release button.
  11. How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 11、 3の画像 1 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 11、 3の画像 2 How to Repair the Broken Toe Strap of a Fabric Sandal: 手順 11、 3の画像 3
    • Pour rubbing alcohol onto a paper towel.
    • Rub the paper towel over the shoe to remove pencil marks and excess glue.
終わりに
If you properly follow the instructions in this guide, your sandal will be repaired to a lasting, wearable condition.
作成者
2人の作成者と共同で作成されました。
Kulthum Lakha
メンバー登録日: 09/28/21
193 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-2, Raign Fall 2021 University of North Texas, Team 1-2, Raign Fall 2021人のメンバー
UNT-RAIGN-F21S1G2
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 32
過去 30 日: 90
今までの合計 2,753
