メインコンテンツにスキップ
How to Repair the Base of a Dresser
必要な工具と部品
  1. How to Repair the Base of a Dresser, How to Repair the Base of a Dresser: 手順 1、 1の画像 1
    • Remove all drawers from the dresser.
  2. How to Repair the Base of a Dresser: 手順 2、 1の画像 1
    • Turn the dresser upside so that the bottom is facing up.
    • You may need to turn the dresser on its side for easier access to the damaged portion of the base.
  3. How to Repair the Base of a Dresser: 手順 3、 1の画像 1
    • Using a pair of pliers, remove the existing staples from the bottom of the dresser.
  4. How to Repair the Base of a Dresser: 手順 4、 1の画像 1
    • Remove the piece of hardboard and realign it so that it is in the position you desire.
  5. How to Repair the Base of a Dresser: 手順 5、 1の画像 1
    • Use the staple gun to staple the hardboard back to the frame of the dresser.
    • Never have staples in the staple gun until you are ready to use it and keep all hands at a safe distance from the staple gun while in use to minimize the risk of an injury.
  6. How to Repair the Base of a Dresser: 手順 6、 1の画像 1
    • Using the tape measure, measure the distance between the two sides of the dresser frame and then cut a beam of wood to fit these specifications.
    • Be sure to measure the beam of wood as close as possible to ensure that the beam is not visible while viewing the dresser and it will not impede the drawers in any way.
  7. How to Repair the Base of a Dresser: 手順 7、 1の画像 1
    • Using the drill, screw the beam of wood into place.
    • It is not necessary to drill guide holes into the beam of wood before screwing the beam into place.
終わりに
To reassemble your dresser, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Caitlin Serafine
メンバー登録日: 07/12/17
129 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team S1-G3, Rauch Summer 2017 Texas Tech, Team S1-G3, Rauch Summer 2017人のメンバー
TTU-RAUCH-SU17S1G3
3 メンバー
1のガイドは作成済み
コメント 1 件
Hmm not sure how do refix the dressers
Megan Gellert - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 50
今までの合計 4,536
