メインコンテンツにスキップ
How to Repair an Unstable Sliding Door
必要な工具と部品
  1. How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: 手順 1、 3の画像 1 How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: 手順 1、 3の画像 2 How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: 手順 1、 3の画像 3
    • Investigate the cause of the unstable sliding door.
    • In this case you can see the sliding tract isn't aligned with the bottom roller.
    • You can also see that the screw at the base has been dislodged.
  2. How to Repair an Unstable Sliding Door: 手順 2、 3の画像 1 How to Repair an Unstable Sliding Door: 手順 2、 3の画像 2 How to Repair an Unstable Sliding Door: 手順 2、 3の画像 3
    • Remove the screws used to hold the door in place with a Phillips screwdriver.
    • Once the doors are loose from the tracks, remove them.
  3. How to Repair an Unstable Sliding Door: 手順 3、 3の画像 1 How to Repair an Unstable Sliding Door: 手順 3、 3の画像 2 How to Repair an Unstable Sliding Door: 手順 3、 3の画像 3
    • Check to see that the rollers are securely in place.
    • If there are any bits of debris present on the rollers or the tracks, clean it off with isopropyl alcohol and a clean rag.
  4. How to Repair an Unstable Sliding Door: 手順 4、 3の画像 1 How to Repair an Unstable Sliding Door: 手順 4、 3の画像 2 How to Repair an Unstable Sliding Door: 手順 4、 3の画像 3
    • Place the doors back on the rollers.
    • Replace the screws you removed earlier.
    • Check that the rollers move freely. You can test this by using your hands to roll them forward to your satisfaction.
  5. How to Repair an Unstable Sliding Door: 手順 5、 3の画像 1 How to Repair an Unstable Sliding Door: 手順 5、 3の画像 2 How to Repair an Unstable Sliding Door: 手順 5、 3の画像 3
    • Align the door on both tracks.
    • Start by attaching the head of the door first and then lower body into the track. Avoid forcing into the track as this might damage the rollers.
    • Make sure that it is aligned properly so it does not fall out in the future.
ゴール
作成者
2人の作成者と共同で作成されました。
Barabonye Longjohn
メンバー登録日: 09/21/20
121 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G30, Woodhouse Fall 2020 York University, Team S1-G30, Woodhouse Fall 2020人のメンバー
YORK-WOODHOUSE-F20S1G30
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 324
